MULDERIZED AP1 HEADLIGHT
Old Jan 21, 2008 | 06:41 PM
  #181
AP1_S2k's Avatar
Originally Posted by its_mee_tuan,Jan 21 2008, 12:41 PM
so.. I couldnt find plastic primer and "opted" to use the krylone plastic paint (the one that doesnt need primer) instead. Well it ended up being really really runny and bled under the tape. So i ended up jus making my headlights naked.. woooo
just get some laquer thinner and rub it off. The paint should come off with no big issue
Old Jan 22, 2008 | 08:23 PM
  #182
tph4m's Avatar
yea that krylon stuff was for plastic, thats why i figure it would be okay. I didnt realize how thin the shit was. Wouldnt lacquer thinner melt the plastic?
Old Jan 22, 2008 | 08:45 PM
  #183
GyozA's Avatar
No, just don't use a ton of it. Use little dabs and dry it off. I think that's what Mulder had to do to s2000shifter's diffusers. Ask him before you do it because I'm not 100% positive.
Old Jan 23, 2008 | 04:04 AM
  #184
AP1_S2k's Avatar
No its not strong enough to melt the plastic. you use it in small amounts. If you are really afraid of thinner melting the plastic thin you can try using some qwik prep or first clean. They are made by Dupont and you use them when preping a car for paint. They clean but are not as strong as lacquer thinner but they might not have enough ass to peal up the paint.
Old Jan 23, 2008 | 10:09 AM
  #185
MULDER's Avatar
DO NOT CUT CORNERS!
I saw a set of diffusers that a guy in the Florida forums was trying to pass off as one of mine. He had opted to paint a different part of the diffuser which looked wierd.... like I had warned... then he didn't use the paints I had chosen but others including a GLOSS black..... needless to say, I don't think they ever went into the headlights before he realized his mistake.
Old Jan 23, 2008 | 12:12 PM
  #186
NVMY4N's Avatar
Originally Posted by MULDER,Jan 23 2008, 02:09 PM
DO NOT CUT CORNERS!
pwn3d
Old Jan 24, 2008 | 04:38 PM
  #187
EricLee7481's Avatar
Is it possible to use the dremel tool to do the sanding? Just picked up a cordless dremel tool and very interested in trying it out.
Thanks
Eric
Old Jan 24, 2008 | 07:42 PM
  #188
AP1_S2k's Avatar
Thanks
Eric
no
just use some paper and do it by hand
Old Jan 25, 2008 | 05:17 AM
  #189
MULDER's Avatar
I agree. You will end up:
A. melting the plastic
B. over sanding, causing loss of detail and possibly uneven surfaces
All you want to do is score the surface slightly so that it will hold the base coat, anything more than that and you are ruining them.
Don't be lazy guys.... and don't cut corners. If anyone doesn't want to put the time and work into them to do them right, send them to me and I will do them for you.... for a fee ofcourse
Old Jan 25, 2008 | 03:03 PM
  #190
daktruckie99's Avatar
The advantage of doing this during the summer was siting on my porch with a drink and cigar and sanding my diffusers in the sunshine. Taking my time and doing it right was hardly a burden
As with Mulder, do it once, do it right!
