My 2.5L Stroker Engine Buildup Thread
Old Jun 8, 2006 | 05:57 AM
  #121
Stoner_1's Avatar
Originally Posted by ya@inlinepro,May 3 2006, 06:07 PM
I'll be using the aem EMS as well.
When you've gotten your EMS setup and the engine running smooth can I look at your base map? (I'd like to do a comparison)
Old Jun 13, 2006 | 06:38 AM
  #122
ADAM_ROB_UK's Avatar
this hass dropped off the second side of the world........
what has happened to the every day or so updates... all we seem to be getting not it patchy info.
must not be too good for any people who where thinking about buying this kit, because if your wanting to settle reliability issues and make this thread about the whole engine build up from start to end + dyno #'s, then you have kinda failed at keeping the interest up.
Yes i can understand work my be busy, and you may be getting a lot of customers.. but an update take 5 minuts of time. you dont need to post pictures just a general update to keep people interest up etc.....
so what has happened to this engine ?
adam
Old Jun 13, 2006 | 09:47 AM
  #123
jzz30's Avatar
Originally Posted by ya@inlinepro,Jun 5 2006, 06:32 PM
MOTOR IS COMPLETE!
here are the final pics before i create a new thread on the DYNO #'s!!!
My valve cover is on the way from the powder coater. so these will be the final pics until it is in my car.
hope ya'll enjoyed everything.
like he said he will make a new post once its in the car. its kinda pointless to shoot another pic.
Old Jun 13, 2006 | 09:48 AM
  #124
S2000_Europe's Avatar
Talking
adam
Come on Adam do not be impatient. This kind of jobs takes time, tuners usually are busy .
Cheers
Juan
Old Jun 13, 2006 | 11:37 AM
  #125
Race Miata's Avatar
[QUOTE=mbilderback,Jun 6 2006, 12:52 PM]Real question is, what will the final torque numbers be?
Old Jun 13, 2006 | 02:13 PM
  #126
Silver9k's Avatar
Originally Posted by Race Miata,Jun 13 2006, 11:37 AM
Assuming:
100% VE
13 CR
14.7psi atmosphere pressure at sea level
2488cc
max torque on the crank = AP x CR x VE x CC / 2471
= 14.7 x 13 x 1.00 x 2488 / 2471
= 192.4 lbf
Even if such engine can keep 100% VE at 8000rpm, it'll produce
294.50hp at the crank. Assuming 40hp loss which may be too optimistic, that's 254.5rwhp.
To get 285 rwhp, that means 325hp or more at the crank. To make such HP with such engine, you need 100% VE at 8828rpm (IOW, a perfectly flat torque curve to 8828rpm which IMO is very hard if not impossible).
EDIT: must be something wrong with my calculations. I can't get the stock numbers with these calculations either. Somebody please correct me while I'm searching links to the equation on the Internet now.
well using stock numbers and your calc its about 40 ftlbs off...so, in that case, you may be able to assume that extra 30hp is quite possible...It would be nice.
Old Jun 13, 2006 | 04:29 PM
  #127
Race Miata's Avatar
Yeah, sounds like the #s are possible. I still can't find what's wrong with my calculations. Oh well. Looking forward to the numbers.
Old Jun 13, 2006 | 06:16 PM
  #128
white_S2000@16's Avatar
these numbers are close but i can already say are very far off of what this motor "should" do. iI ihada 2.5L and made 250 WHEEL hp and 189ft/lb with 11.5:1 CR and a stock head, headers, cams.
When iyou take into acount all the upgraded parts this set up has compared to mine i don't feel bad sayinig this has potential for over 300hp, the intake manifold will for sure be a major limiting factor of this set up. Also part of me thinks the cams my hurt this set up dependinig how the head work was done, i think the stock 2.2L cams would do better Also for all the calculatioins i have done for drivetrain losses in the S2000 form actual dyno #s of miutiple cars there is typically a 16.7 ~ 17% loss the through the tranny.
on a side note all these wonderful picitures of the build up and none of the key to it all the magical crankshaft
-Matt
p.s heres my old dyno
Old Jun 13, 2006 | 07:36 PM
  #129
ya@inlinepro's Avatar
adam
My next update will be when the dyno sheet comes up.
this thread was for the motor build up, and its complete.
Old Jun 13, 2006 | 09:27 PM
  #130
Silver9k's Avatar
are you going to at least put a link in this thread to the dyno? Cause I don't want to miss it
