Is my alignment ok?
Old Sep 15, 2005 | 02:36 PM
LubedKoala's Avatar
Default Is my alignment ok?
This is what my alignment is set to:
LF Toe: -0.05
RF Toe: 0.00
LR Toe: 0.25
RR Toe: 0.20
LF Camber: -0.40
RF Camber: -0.50
LR Camber: -1.50
RR Camber: -1.50
LF Castor: 5.90
RF Castor: 6.10
I don't know much about this, but the mechanic said there was a specified range (set by honda) that it can be in, and as long as it's in that range everything is ok. I always thought the left and right setting should match. My car is not lowered by the way.
Is this is alignment done correctly? Also, how abnormal should my tire wear be? I say this because my front tires were showing wire on the inside tread, and on the outside it was ok. There was a significant wear difference. I know the camber is a factor with our cars, but i felt like the wear was too abnormal. Hence the alignment I had done.
Old Sep 15, 2005 | 02:50 PM
LubedKoala's Avatar
I did read the technical forums, but I still want your responses on this.
Old Sep 17, 2005 | 05:07 PM
LubedKoala's Avatar
You guys suck...
blasphemy101
Jul 12, 2011 09:05 AM
ChineseDelivery
Jan 10, 2009 10:22 PM
Spa4eva
54
Apr 8, 2006 09:45 AM
Squeezer
Mar 28, 2003 09:32 AM
