my compression numbers changed...
a few weeks ago i did a compression test on my 03 ap1 w/ 134000 miles. the numbers were 215-225 all 4 cylinders. I did a compression test day again and this numbers came out to be 170-180 all 4 cylinders. I'm confused
could it be that I used a different compression tester?
Different compression testers can show different numbers. Was the car warmed up both times? Hold the gas pedal all the way down? Battery have enough juice to crank enough for the numbers to hit the max they would go?
Was it on a hot/warm engine?
Even with jumper cables attached to my civic my car wasn't making enough cranking power to get higher numbers. Had to let it sit for a long time. So my battery was going out but if you have a weak battery could be that as well but would most likely give inconsistent numbers.
Most likely just different numbers due to a different compression tester.
