my compression numbers changed...
Old Aug 5, 2011 | 09:12 PM
s2000maniac's Avatar
Originally Posted by starchland
A visual inspection might tell you more...
exactly what should I be looking for? thanks
Old Aug 6, 2011 | 02:15 AM
dwight's Avatar
Originally Posted by s2000maniac
I went into a wrong gear couple times and it bounced off the rev limiter. I just wanted to make sure I didnt mess up anything.
The rev limiter is an ECU-based way of preventing the engine from going too fast by limiting power output. Over-revving from mis-shifting has nothing to do with the rev limiter.
https://www.s2ki.com/s2000/topic/467874-help-overrev/
https://www.s2ki.com/s2000/topic/467856-billman-help/
Old Aug 6, 2011 | 06:24 AM
right i meant an over-rev, yea im really worried so i'll take it to a shop to get it inspected.
Old Aug 6, 2011 | 06:29 AM
Moddiction's Avatar
Former Sponsor
If you over revved a couple times you need to get the retainers checked out.
What speed and gear did you over rev to?
Old Aug 6, 2011 | 09:16 AM
Carbon Blue's Avatar
pull the head and check the tops of the pistons, bent valves, missing spark plug tips, scored cylinder walls. How bad of a misshift did you do? The rev limiter will not protect you from a mechanical induced over rev.
Old Aug 6, 2011 | 10:09 AM
TheSteel's Avatar
perhaps you should change your sig to "10k all the way"?
Old Aug 6, 2011 | 12:44 PM
im not 100% sure but it was around 65-75 mph and i think i went into 2nd.
the toffinator
Mar 4, 2016 09:31 AM
Monacos2k
May 31, 2015 04:59 PM
stevenw
Jul 17, 2013 12:20 PM
WarrenW
Sep 18, 2010 06:38 PM
ratfink
May 31, 2007 12:59 PM
