Is my diff in good cond.
Old Sep 4, 2008 | 03:54 PM
Sticky2k's Avatar
Default Is my diff in good cond.
Old Sep 4, 2008 | 04:06 PM
jyeung528's Avatar
what did you do
Old Sep 4, 2008 | 04:56 PM
FitzyS2k's Avatar
it looks in excellent condition. yeah what did you do?
Old Sep 4, 2008 | 04:57 PM
Sticky2k's Avatar
launching
I had about 50+ launches then it finally went.
Old Sep 4, 2008 | 05:30 PM
Revenge's Avatar
It's time for HTG puddy mod
Old Sep 4, 2008 | 05:49 PM
9KRDLIN's Avatar
looks pretty good, you may want to buff out the scuffs.
Old Sep 4, 2008 | 11:14 PM
fastD's Avatar
ya, good to go - after you spend $1500 +/-.
Hope those 50 hole shots were worth it...
Old Sep 5, 2008 | 05:22 AM
ian05s2k's Avatar
looks mint to me
-Ian
Old Sep 5, 2008 | 06:17 AM
mitsu13gman's Avatar
I think I'm just reiterating the sarcasm you've received so far, but the entire rear end is destroyed.
As for the physical limited slip itself?
Tough call. Given that you've grenaded the whole thing, I would err on the side of caution and replace the differential itself as well when you a get a new case and gearset. Given the unintended loads all the elements of that case experienced as a result of the broken teeth bouncing around in there, I can't say I'd have a lot of faith that the differential isn't tweaked at least a little.
So to directly answer your question, I would consider the diff to be highly suspect, if not outright damaged.
edit to add:
Also, some better, closeup pics of the diff itself would help, since you only have 2 marginally useful shots of the diff, and the rest showing the scattershot result of excessively launching on the stock diff.
Old Sep 5, 2008 | 07:11 AM
TubeDriver's Avatar
Originally Posted by Sticky2k,Sep 4 2008, 05:54 PM
Only 50 launches and your diff looks like that?
I have *hundreds* of 4.5-5k launches on 275 Hoosier A6 and my diff sounds and feels fine.
s2kmiami69
Mar 23, 2013 12:05 PM
1SlowSi
May 11, 2011 12:55 PM
Vincey
Jul 29, 2009 07:39 AM
HMFIC
Jul 15, 2009 05:36 PM
yarou
Apr 18, 2007 04:39 AM
