My headlight bulb is dead?
Old Sep 25, 2011 | 09:15 AM
Dumas2k's Avatar
Default My headlight bulb is dead?
My driver side headlight would be dim for a second then turn off. Its not on all the way but barley on. Would it be the bulb or ballast that needs to be changed out?
Old Sep 25, 2011 | 12:57 PM
Dumas2k's Avatar
? bulb or ballast?
Old Sep 26, 2011 | 11:32 AM
vtec9's Avatar
So does it turn all the way on, then go very dim? Or does it turn on dim then shut off. Or does it turn on all the way, then shut off completely?
When I get bad HIDs, they usually will ignite ok at first, but then turn off completely shortly after.. eventually they won't turn on at all.
Anyway, the best way to check this is to swap the known working bulb with the faulty one. I.e., take the bulb out of the side that's working and stick it in the side that is giving you problems. If the bulb works, it's the bulb.. if it gives you the same issue, it's most likely the ballast.
Old Sep 26, 2011 | 03:57 PM
Dumas2k's Avatar
It lights up dim for a slight second then would completly turn off.
Old Sep 27, 2011 | 06:45 AM
vtec9's Avatar
sounds like the bulb is almost dead.
Old Sep 27, 2011 | 11:57 AM
robotvoice's Avatar
Swap your good bulb over to the other headlight to see if it's a bad bulb or ballast, sounds like a bulb though from what you have mentioned. If it does turn out to be the bulb, buy a brand new PAIR and replace both at the same time. HID bulbs lose light output and shift in color over time so they need to be replaced in pairs. Also, DON'T buy them from the dealership, they are way overpriced.
Old Sep 29, 2011 | 08:37 AM
vtec9's Avatar
meh, don't NEED to be replaced in pairs.. a working bulb is a working bulb, albeit with higher color temp and slightly less light output.
But definitely buy them off ebay or amazon.. should be able to find a pair for $80 or single for around $50.
Old Sep 29, 2011 | 11:43 AM
Clark's Avatar
It is kinda silly not to replace them in pairs. Most headlight bulbs go out within a close timeframe of each other anyway. Replace the pair while you're at it, and keep the 3rd as a spare.
Old Sep 29, 2011 | 06:02 PM
DFWs2k's Avatar
or buy them off js2k.com for under $30 shipped
Old Sep 30, 2011 | 05:03 AM
robotvoice's Avatar
It's not a "need" but with HID bulbs but I would still highly recommend it, especially if the good bulb has been running for a few years.
truancy143
Mar 20, 2016 10:25 PM
Lou-AP1
Aug 9, 2012 11:49 PM
vtec9
Apr 27, 2011 05:52 AM
Aaw Dude
Mar 22, 2006 08:21 PM
learnerspermit
Sep 1, 2005 08:23 AM
