My impressions: Zero camber and otherwise stock alignment settings
First off let me start by sharing what I have done to the car. MUZ front lower cross brace , APC S.T.B. , four rear wheels machined inside to fit for rotation purposes with Fulda Extremo tires size 225/45. With this setup I had the usual inside wearing of the tires eased a bit by rotating and a good dose of oversteer on uneven roads. When the car was completely stock I had a slippery feeling rear end, the back end always kicked out without warning. After running this setup for over a year I was happy with the ability to rotate tires, more firmly planted feeling rear but the increased oversteer was getting too annoying lately. I decided to go get an alignment with zero camber and everything else set to spec. to help reduce the oversteer and tire wear. I did a lot of spirited driving today and the car seems fantastic so far. The oversteer problem is gone and the cornering performance feels just as good as before. I felt just as confident as before flying around a large sweeping on ramp section of interstate this morning. I should have more even wear on my tires and I don't feel at all like I have sacrificed my cornering performance in a negative way. This is my daily driver and not a weekend autocross car so I am very happy with the current alignment settings.
you had 2 rear wheels machined to fit in the front? what did the machine shop do?
That's strange. I can't imagine how REDUCING camber would give more grip to the rear during cornering. Increasing toe would have that effect, though. Was your previous alignment lacking rear toe-in?
so you reduced tire size in the rear and then wondered why you got oversteer? and you think removing camber is going to solve your problem?
Seriously dude, if you are having this many problems driving the car, you may consider buying an RSX, or something FWD. The s2000 is a wonderful handling car, but you have to know how to drive it to get any enjoyment out of it. Machining the wheel makes it not hubcentric on the rear when you mount it, which will result in vibrations and additional strain on the lugs.
ohhhhhhhhh, hubcentricity...
i guess if he went thru the effort to machine all the rears out, he could also have a plastic shop make some hubcentric rings to place into the wheels for the rears only.
