My TCT exploded
Old Sep 30, 2007 | 08:00 AM
ZCP M3's Avatar
Default My TCT exploded
Hey all,
Just as the title says, when i pulled my auto TCT out, everything flew out of it. I found an exploded view of it and reassembled it correctly, but i cannot get it to retract long enough to put it back in the case. Anyone have a trick to do this?
Thanks in advance,
-Zach
Old Sep 30, 2007 | 08:17 AM
Stratocaster's Avatar
You have to use a bolt. Remove the back cover, stick the bolt in and screw the thing back to compress the pistion. When the piston is back, insert the pin to keep it in place. The pin is an OEM part and is referanced in the service manual. Sounds like you don't have one, and you need to get one.
Old Sep 30, 2007 | 08:19 AM
ZCP M3's Avatar
I was hoping someone had the size of the bolt handy as i dont see the size listed anywhere. Will a paperclip suffice to keep the piston back or will i have to make a special trip to my Honda dealer for that pin?
Old Sep 30, 2007 | 08:25 AM
S2KPUDDYDAD's Avatar
The long bolt with the nut shown in this pic is what you need.
Old Sep 30, 2007 | 09:09 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The bolt needed is 5mm X .80 thread.
Old Sep 30, 2007 | 09:29 AM
SpitfireS's Avatar
Billman250 Posted on Sep 30 2007, 07:09 PM
OIW, a standard M5 bolt.
4" or 100mm long.
M5x100
Old Sep 30, 2007 | 10:24 AM
Thanks guys I could not remember but I do have a nice pic
Old Sep 30, 2007 | 03:38 PM
ZCP M3's Avatar
Picked up an M5X50 and that did the trick, thanks everyone!
xasrielx
Jan 24, 2010 11:26 AM
peters2000
Nov 29, 2009 07:19 AM
LegendaryHarry
Jan 28, 2009 11:47 AM
LostMotion
Nov 14, 2008 10:06 AM
sharptech
Dec 27, 2007 04:37 PM
