MY00 Clutch Issue
Old Nov 14, 2004 | 09:09 AM
bighersh's Avatar
Default MY00 Clutch Issue
i drive a MY00 and lately have been having some clutch problems. it only happens once in a while at no particular time. when starting off in 1st i will get resistance and some squeaking when letting the clutch out as i get on the gas. like i said, this only happens once in a while. any ideas? thanks
Old Nov 14, 2004 | 04:08 PM
xviper's Avatar
There are several possibilities.
-squeaky master cylinder
-squeaky slave cylinder
-squeaky release fork
-squeaky throw out bearing.
-worn out clutch disc
Have you ever changed the fluid? You can grease the release fork. You might be able to eliminate the master cylinder by listening under the hood while someone pushes on the clutch. Same goes for the slave cylinder if you can jack up the car. The other stuff, you'd have to do a clutch job.
Old Nov 15, 2004 | 05:47 AM
bighersh's Avatar
thanks for tips. i just changed the fluid last time i changed my oil, roughly 25k miles on the car at that point. the odd thing to me is that it has happend maybe three times . i will explore the options you listed. thanks again.
s2000maniac
May 30, 2012 02:13 PM
realmike15
May 4, 2011 09:10 AM
Rosso_Corsa
Oct 7, 2010 08:39 PM
vteconly
Sep 1, 2006 10:02 AM
Big_Al
Nov 11, 2005 11:45 AM
