MY04 keep stalling itself...
Old Feb 21, 2005 | 04:03 AM
jwkim's Avatar
Former Sponsor
Default MY04 keep stalling itself...
MY friend has MY04 USA spec w/ 30k miles.
Recently his car started to stall itself at the stoplight.
ECU wont hold up the idle. The car idles very low and it keeps stalling.
Also sometimes it runs very jerky at lower rpm. 2-4k rpm.
Dealer replaced MAP sensor but problem still exist.
What could be next?? spark plugs? or maybe Oxygen sensor?
TIA
Old Feb 21, 2005 | 07:52 AM
xviper's Avatar
Idle Air Control, vacuum leak, bad gas, clogged injectors, dirty air filter, bad fuel pump, bad fuel pressure reg, lazy ECU. Or it could be just a severe case of heat soak.
Old Feb 21, 2005 | 09:21 AM
jerrypeterson's Avatar
I'd recommend that he continue sending it to the dealership under warrantee before you start monkey.
Old Feb 21, 2005 | 10:49 AM
xviper's Avatar
You should not be looking into those things I posted up on your own. These are only to give you some idea of what it "might" be, since you asked. If you start fiddling with anything, the warranty will not cover.
Old Feb 21, 2005 | 01:26 PM
blackfx35's Avatar
I have the same problem with my04. My dealer replaced the map sensor, but it still stalls occasionally as I try to come to a stop...rpm drops and comes back up. I only have 3000 miles on my car...my dealer can't figure out what's wrong with the car.
Old Feb 21, 2005 | 02:10 PM
xviper's Avatar
If it doesn't actually die, leave it for a few episodes without "helping" it (ie, keep your foot off the gas, don't try to save it). It might just learn on its own. If it dies or if it never learns, then you have a problem. It may just be that the ECU is "slow" or it's having a brain fart. Mine does this every summer. It always learns after a few near death experiences. If you try to help it or try to fix it in some way, it may never learn.
Old Feb 21, 2005 | 03:24 PM
sexy2k's Avatar
I have had this EXACT same problem but it was when i bent my valves. Have you ever mis shifted, over reved or anything? But either way, warrenty should be able to cover everything
booost02
Mar 30, 2010 12:29 PM
MB
Jun 6, 2006 02:32 AM
MB
Mar 2, 2006 12:18 PM
turboelan
May 31, 2004 04:20 AM
bunjimobile
Mar 27, 2004 01:08 AM
