Mystery CEL - no code displays
Old Aug 27, 2003 | 10:31 AM
johnnydev's Avatar
Default Mystery CEL - no code displays
I had some valve work done to repair bent valves. Didn't go to a dealer because they wanted nearly $2k for the work. Went to a shop that seems to be really good but now they can't resolve the check engine light being on. When they connect the OBDII computer, there is no error code. They've had it in 3 times (at no charge to me) but have had no luck. The most recent time they replaced the VTEC oil pressure sensor thinking that may be the issue. They have been really good about trying to figure this thing out but they are stumped.
Any of you seen this before or have any ideas about where else to look?
All help is greatly appreciated.
JD
Old Aug 27, 2003 | 10:37 AM
Gernby's Avatar
Former Sponsor
Sounds fishy to me. Does the CEL turn off if you reset the ECU?
Old Aug 27, 2003 | 10:45 AM
johnnydev's Avatar
[QUOTE]Originally posted by gernby
[B]Sounds fishy to me.
Old Aug 27, 2003 | 10:53 AM
Gernby's Avatar
Former Sponsor
Reset the ECU, drive it until the light comes on, then go to an Autozone to pull the code. Maybe the shop's OBDII computer is not fully compatible.
Old Aug 27, 2003 | 08:05 PM
spider's Avatar
Johnny,
You are alive!
Go to UL's shop and maybe he can take a look for you.
Old Sep 19, 2003 | 12:07 PM
johnnydev's Avatar
Update! Well I ended up buying a OBD reader - $100 at Kragen. Couldn't get AutoZone or anyone else to loan one. So...
I pulled a code, P0411 "Secondary Air Injection Incorrect Upstream Flow Detected"
Any idea what that is? Thanks!
Hey Spider - yea I'm alive and well just freakin busy. I'll make a gathering soon.
Old Sep 19, 2003 | 12:14 PM
SsamJang's Avatar
do a search.. i think alot of people have had that code come up to them.. including me.. check one of the valves on the hoses that are near the airbox.. mine was placed the other way
Old Sep 19, 2003 | 12:16 PM
Gernby's Avatar
Former Sponsor
I think you can look the code up in the Helm's manual for more information.
Old Sep 19, 2003 | 12:41 PM
RedY2KS2k's Avatar
Helm's DTC P0411: Abnormality of Air Flowing in the Air Control Valve System.
There's about 3 pages of procedure. Since the head was just off your car, I'd wager that they got a couple of hoses switched or wires hooked up wrong. It may be a pain in the butt to find, but should be easy and cheap to correct once you find it.
Old Sep 19, 2003 | 01:01 PM
RedY2KS2k's Avatar
I've looked a little further. The first thing I'd check is the two vacuum hoses to the Air Control Solenoid Valve. Because it has two hose connections, it would be easy to inadvertently reverse them.
According to the diagram I'm looking at, the hose connected to the bottom connector should go down to the Air Control Valve Vacuum Tank, a rectangular box. The upper hose should go towards the rear of the car, to the round Air Control Valve. Probably the easiest way would be to start at the round Air Control Valve at the rear of the engine, kind of between the intake manifold and the valve cover. It only has one hose, so you could trace that hose forward to the solenoid valve.
Keep in mind that I wrote these descriptions from the diagram in the manual without looking at the car.
