Mystery problem with car..
You know from my own personal experience, it sounds like you have a loose vacuum hose somewhere. This will cause some of the symptoms you've been explaining, although it might/ might not be related to the engine codes the car is throwing out.
I would suggest looking around your engine bay, particularly around the intake area for a vacuum hose that has slipped off. This would cause major hesitation, crappy idle, engine stalling out, etc. Just basing it off your experience.
Originally Posted by 707S2K,Aug 7 2008, 11:11 AM
After reading your thread again, Im almost positive you have a loose/ disconnected vacuum hose somewhere. Especially since you noticed the change was very gradual, and not immediate.
Are there any others? Any chance that the two boxes that the vaccuum hoses connect to are bad? What are those anyway? One is the little black cylinder that was originally on the top rear corner of the intake box, and the other is a big black peice that attaches to the crossmember.
My only other suggestion is to see if you can swap out your ECU with someone elses stock ECU and see if that might have a malfunction. As long as you guys are the same year/ model, I believe they should be mapped the same from the factory. That way you can narrow it down to something mechanical if the swap is unsuccesful.
Originally Posted by Slows2k,Aug 7 2008, 06:23 PM
No easy immobilizer bypass to swap a test PCM.
You ever get as fuel pressure check?
