Need advice!...Check engine light with test pipe:
Old Sep 12, 2002 | 12:59 PM
  #61
swoosh's Avatar
dersark, They're under the black cover on top of the red thing , under the hood
Old Sep 17, 2002 | 07:13 AM
  #62
cbender's Avatar
Latest update: the new part went in yesterday. An hour's test drive yesterday afternoon and thus far no MIL. Will keep you posted. I'm doing an S2Ki drive in PA-MD this weekend so I'll have the chance to run the new simulator through virtually all driving conditions to see if anything triggers a check light.
Old Sep 20, 2002 | 06:21 AM
  #63
cbender's Avatar
The new simulator unit went in. The MIL came on. So it goes. I've passed the MIL code on to Caspers and they say they'll have a new part for me soon. I suspect that the next iteration will involve running a wire to the front O2 sensor in order to read its signal and thus provide both the front and rear signals to the simulator in order for the simulator to generate the appropriate signal to the ECU from the rear sensor. I remain confident that Caspers will get this fixed (in large measure b/c they have a number of orders on hold while I play the role of beta tester). I'll keep you posted.
Old Sep 20, 2002 | 09:05 AM
  #64
AndyP's Avatar
Thanks for hanging in there cbender. I would have given up by now.
Old Sep 20, 2002 | 09:11 AM
  #65
cbender's Avatar
Pure stubborness and I'd like the MIL to otherwise work.
Old Sep 20, 2002 | 09:12 AM
  #66
cbender's Avatar
But you can guys are welcome to send me a six-pack for being your beta tester.... Sierra Nevada Pale Ale, pls... :-)
Old Sep 20, 2002 | 10:21 AM
  #67
schwett's Avatar
i know marcucci mentioned this, and you said you passed it on to your guy, but have you simply tried a resistor in the signal from the primary o2 to feed the secondary o2? from what i can tell, there's absolutely no difference in the behavior of the ecu relative to o2 sensor values on an s2k.
[QUOTE]Originally posted by cbender
[B]But you can guys are welcome to send me a six-pack for being your beta tester.... Sierra Nevada Pale Ale, pls...
Old Sep 20, 2002 | 01:03 PM
  #68
cbender's Avatar
Hi Schwett,
I've been preoccupied by other things, so I've not tried Marcucci's solution (although, I did pass it on to Caspers). I didn't bother trying because they really do seem like they know what they're doing. If this next iteration -- which I suspect will involve pulling the signal off the front sensor -- doesn't work, then I'll give Marcucci's solution a try. But thanks for reminding me it's an option. I just have other things on my list and keep thinking, "this time, Caspers will have gotten it right..." :-)
PS: I'm still puzzling over your earlier post. I confess, it went over my head. Way over my head. But the car's running pretty good, so I'm not so worried about the tuning these days.
Old Sep 20, 2002 | 01:06 PM
  #69
cbender's Avatar
Did you remind me of Marcucci's solution to avoid kicking up a six-pack of beer? :-)
Old Sep 20, 2002 | 02:20 PM
  #70
schwett's Avatar
nope, just trying to save you some hassle........ i always like to support manufacturers and consumers of alcohol.
[B]Did you remind me of Marcucci's solution to avoid kicking up a six-pack of beer?
