Need Engine Number
Old Feb 24, 2022 | 09:43 PM
robjoshua228@yahoo.com's Avatar
Default Need Engine Number
My shipper, for some odd reason, wants to know the chassis number as well as the engine number, can someone please help me identify the location?
Much appreciated.
Old Feb 24, 2022 | 10:38 PM
jaymz's Avatar
https://cimg4.ibsrv.net/gimg/www.s2k...5561fbd5ed.jpg
Old Feb 25, 2022 | 06:41 AM
Thank you but that will not do since I am not tearing down an engine.
I have been forwarded the number E22C1-1060, does that make sense for an engine number?
Cheers.
Old Feb 25, 2022 | 06:43 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You don’t need to tear down the engine to see the number. It is visible, located in the left front corner of the engine.
Old Feb 25, 2022 | 08:18 AM
Chuck S's Avatar
You looking for the part number or the engine VIN (visible with a mirror on the back of the engine head) which I believe should match the chassis VIN?
-- Chuck
Old Feb 25, 2022 | 10:44 AM
Billman250's Avatar
Top Answer: 1
The tag on the back of the head is the VIN number. It is not the engine number.
Old Feb 25, 2022 | 11:27 AM
twohoos's Avatar
Yes and no. The first letter should be F, and the serial number is 7 digits. So your engine number is probably F22C1-1060xxx, where the last three digits might not have been visible to whoever was looking at it. (Incidentally, the "6" in the 3rd digit of the serial number indicates the engine was built for an '08 model.)
Old Feb 25, 2022 | 01:33 PM
Chuck S's Avatar
Am I correct that VIN on the back of the engine should match the chassis?
-- Chuck
Old Feb 25, 2022 | 01:39 PM
Billman250's Avatar
Top Answer: 1
Correct ^
The engine cylinder head and the transmission case have a removable (via drilling) green tag with the car’s VIN.
The engine number (typically off a few numbers from the VIN) is stamped in the block.
Old Feb 25, 2022 | 07:04 PM
Chuck S's Avatar
Thanks,
-- Chuck
