Need to grease the ragtop mechanisms?
Is greasing the ragtop mechanisms necessary even if they operate fine without any squeeky noises? Or are they supposed to work without lube? I guess, I'm just wondering if I should include lubing the joints and bars that move the ragtop as a regular maintenance item or is it even necessary?
Originally Posted by SIIK2NR,Jul 24 2007, 05:18 PM
white lithium grease and it's "preventative" maintenance....
I got some for 3 bucks at local auto parts store. It came with a little straw to spray with. To be honest with you I don't even know if I got any in there. I did it while the top was up, then I lowered it halfway and did it again.
If you use a spray lithium grease hold a rag cupped behind or around the area you are spraying to help control overspray.
You should be able to find it at an auto parts store like tekstar said. I know Honda has a spray lithium grease at the dealer. I'm pretty sure there should be the equivalent at an auto parts store. I know Permatex has a tube, maybe they have spray also.
S2K DRIFTER
Dec 22, 2005 01:59 PM
