need help
Old Nov 17, 2014 | 10:38 AM
cesarortiz's Avatar
Default need help
ok so i started getting the weird vibrations at PT in 6th gear once i let go of the gas pedal completely the vibrations stops, once i accelerate the vibration stops again but if i have the throttle like very light in ,(PT)
the vibrations come in and it is starting to feel worse than before ..
i read topic on a common problem like this i already added axle spacers and also i had read that sometimes the nut thats by the drive shaft gets loose and that causes vibrations so i took it to my friend witch is a mechanic and he torqued the nut and added the spacers to the axels the vibration went away
BUT then i went tracking this sat and now the vibration is back
what can it be you guys need help please..
Old Nov 19, 2014 | 07:53 AM
cesarortiz's Avatar
anyone
Old Nov 20, 2014 | 08:08 AM
Car Analogy's Avatar
The spacers only work if there is not a lot of wear already. A more effective fix is to swap them left to right. There is a diy on it in here somewhere.
Old Nov 20, 2014 | 08:28 AM
cesarortiz's Avatar
i already did that a while back when i would get vibrations on 1st 2nd 3rd gear
i swapped the cv buckets and the problem went away.
but I'm at the same again but only in 6th gear.
DDAP2S2K
Dec 31, 2011 05:59 AM
fastkx125
May 12, 2011 03:29 PM
Nick.
Mar 10, 2010 12:33 PM
JimmyB
Jul 11, 2008 06:42 PM
j66
Nov 2, 2006 12:29 AM
