Need Help
Old Apr 1, 2024 | 06:42 AM
R00567's Avatar
Check your oxygen sensors. I had a burnt out secondary / primary and there were not throwing codes. It was a intermittent failure and my car was doing similar shenanigans as to what you were describing...
Old Apr 2, 2024 | 03:31 PM
eporras's Avatar
Default Update
So I tested the sensor with a voltmeter to see if it was working and the sensor does work. When testing the sensor on ohms on the voltmeter the number changes as I move the throttle back and forth so now I know the sensor works. I also tested the wire harness plug to see if it was getting power and it is I’m getting 5v like it should. So why does it give me that p0122 code
Old Apr 2, 2024 | 03:32 PM
eporras's Avatar
I had just recently changed the secondary o2 sensor about 2 months ago
Old Apr 2, 2024 | 05:57 PM
bad_driver's Avatar
I'd definitely clean it, clear the code, and hope it doesn't pop up again.
Savvas
Mar 11, 2017 04:16 PM
Houstonduck
Jun 13, 2012 04:49 AM
Radfords2k
May 17, 2007 09:59 AM
me11jh
Jul 22, 2004 05:34 AM
ytyper
Oct 30, 2003 06:18 AM
