need help
when i got back from my first tour in iraq i decided to turbo my 2001 s2000. so i turbo it did clutch and the ecu i also send my block to golden eagles to get t sleeve and did my pistons and rods also my fuel pump and a 3mm head gasket also arp head studs.. but now when the turbo on my timing chain is slapping my mechanic said under low RPM that it had low oil pressure causing the timin chain to slap . he said it went away at higher RPM cause you brought up the oil pressure .
need help dont knoe wat it is and the mechanic said i should just get a new engine .. which i dont think its right he prob just wants money..
stantaur
Oct 23, 2012 11:17 PM
Spoolin
Jan 29, 2005 04:37 PM
