Need Help, advice, anything would help
Old Dec 15, 2013 | 04:05 PM
Kenneth22's Avatar
Default Need Help, advice, anything would help
One morning about 2 weeks ago my car wouldn't start. I believed it was due to a bent valve issue I had. It would only come on for a second and then die. Later that night after trying a couple times I finally got it to start and idle but when I did it ran funny. It idles high and doesn't register it is running at operating temp. it stays at 2k like the motor is cold. and the cluster is stuck at 0 and the miles aren't registering. the only thing that is working is the rpm. So I dropped my head off at the shop and had my valve train rebuilt. After getting the car back together a couple nights ago and started I am still getting the same codes and results but the motor sounds crisp. Its throwing three codes, a p0118, p0122 and a p500.
I heard about this problem from someone and they told me about soldering in a new wiring harness into the ecu I have but im not sure that is a fix for this situation. If anyone has heard of this or had this same problem please let me know.
Old Dec 16, 2013 | 03:29 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Did you attach the ground to the back of the head?
singlespeed
Mar 17, 2013 01:23 PM
slowpokeS2K
Oct 21, 2012 05:42 AM
cvedral
Feb 10, 2010 08:55 AM
holyshyt222
May 11, 2009 09:11 AM
Frunzman
Nov 13, 2008 11:45 AM
