Need help ASAP
Old Oct 2, 2009 | 08:59 PM
dtmcnamara's Avatar
Default Need help ASAP
Ok so I got home 2 hours ago about to get a nice night sleep and my window decides to be a BITCH...Its stuck down
Not a big deal, I figured I would turn the car off and then back on and still nothing.
There is no noise, nothing at all.
I need to figure out how to manually pull the window up.
Anyone know? PLEASE HELP ME, I HAVE WORK IN LESS THAN 5 HOURS AND I NEED SLEEP!!!
Thanks
Old Oct 2, 2009 | 09:00 PM
cagfoneguy's Avatar
Flip the lockout switch on the drivers door?
Old Oct 2, 2009 | 09:05 PM
dtmcnamara's Avatar
yep...trust me, that was the first thing I did....lol
I did it once in the rain and I swore I would never do it again
trying to find info on how to manually put it up
Old Oct 2, 2009 | 09:17 PM
CKit's Avatar
I don't think it's easy to do. Get some tape and saran wrap. Fix it tomorrow after work.
CKit's Avatar
You have to remove the door panel, IIRC.
dtmcnamara's Avatar
well i just hooked a 12v source to it and it went up and down, did it per the service manual. I then connected it back to the loom and again nothing. Checked the child safety and all and still nothing. Checked the fuses nothing. I decided then to trace the wires and lo-an-behold somehow a wire was pinched and got cut inside the door.
Looks as if the wires came out of the bundle and got caught in the window movement and after x amount of years finally went.
warming up solder iron as we speak. should be an interesting job with only a inch of room to play with...
thanks guys
Old Oct 3, 2009 | 05:43 AM
txs2knoah's Avatar
90 bucks to check it out. lets do it...
Old Oct 3, 2009 | 03:16 PM
XScarAudio's Avatar
great find. instead of solder, go for a crimp if it isn't possible to get the soldering iron in there safely.
Old Oct 3, 2009 | 08:54 PM
s2k aok's Avatar
good job on the fix...
Kingkirk001
Nov 4, 2013 01:22 PM
2SoonS2K
Dec 21, 2012 10:59 AM
phiesope
May 5, 2009 09:26 AM
kalibo
Oct 17, 2007 08:57 AM
BlueS2000Boy
Aug 10, 2003 12:44 PM
