S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Window Squeeks/Grinds when rolling up/down
Old Nov 29, 2012 | 10:09 PM
2SoonS2K's Avatar
Default Window Squeeks/Grinds when rolling up/down
Hey guys my passenger window has started to make a squeaking noise / grinding noise whenever I roll the windows in either direction. Do I need to lube something or does this mean some part of it is dirty and clogged?
I searched for window grind but I got hits for transmissions. Any help would be appreciated as it's very annoying and I feel as if the grinding is harming something. Thanks
Old Dec 2, 2012 | 01:17 PM
croftoncustoms's Avatar
Id recommend getting inside the door and just see whats going. probably need some grease in a joint
Old Dec 2, 2012 | 01:59 PM
LumbarEpidural's Avatar
Try cleaning the seals and applying some silicon grease.
Old Dec 6, 2012 | 07:00 PM
2SoonS2K's Avatar
Thanks i'll try to take the door panel off once i have time.
Old Dec 21, 2012 | 10:59 AM
2SoonS2K's Avatar
So I took off the door panel, and I couldn't really see what I needed to do.
I had a miata before with similar issues and I took the door panel off and that exposed the window channels.
Do any of you guys have any more insight on what it could be? Or where I should be looking at?
turbosix
Nov 20, 2011 12:46 PM
The Raptor
Aug 30, 2009 05:41 PM
dlofneps2k
Apr 11, 2006 02:44 AM
VTEC4-2
May 12, 2004 02:54 PM
Jip69
Dec 19, 2003 09:08 AM
