NEED HELP WITH BEARINGS
Ok, i checked the codes to get the colors for my main bearings and it says i need 2 green and here is where I get confused, 2 yellow/green and 1 green/brown. Honda doesnt sell a color like that does it??? I thought it was always a solid color! So I looked up on Majestic and it doesnt list a yellow/green or a green/brown, just like i thought. Any help on what that means? Does it mean i need a yellow top and green bottom???
Any help would be greatly appreciated.
Thanks
Fadi
Ended up being main bearing!
My mods are in my signature. I launched my car today and when i launched and took off i noticed a noise. My oil light came on and stays on at idle. If i rev over 2000 rpms it goes away. The car is making a wierd noise as well. Its like a metal knocking or clanking noise. It goes from loud to barely noticeable. The noise is not always there. There is a vibration as well. The car drives fine other than the symptoms. I only drove it back home though. Any ideas???I have included a video. I appreciate any help very much.
Thanks
Fadi
Here is the noise:
Car noise video
Thanks
Fadi
Thanks
Fadi
Here is the noise:
Car noise video
If your oil light came on then check your oil.....?
If the light came on then you most likely starved for oil and since its making a weird noise its likely that you spun a rod bearing. Very expensive repair at that point. Dont drive the car until you figure this out or your situation will be 10x worse.
Yeh my first guess would be a spun bearing. I work on my cousins car and almost the same symptoms. His car would have a noticeable noise but when rev up it would go away. I thought it was the valves needed adjustment..after I tighten her up it still made it. So I lower the oil pan and notice a rod bearing sticking out of the rod. But definitely dont drive it anymore till you get it check out.
sounds like a spun rod bearing.
You sure it had enough oil? did you do a two-step when you launched it? was the motor cold when you did it? Don't drive or run the car at all and you might be able to save it!
