NEED HELP engine sound
cylinder no1 the one closest to the front looks like it has a little more carbon than the others but im not sure. Do a compression test and see how that goes then maybe like the one above said try and adjust the valves. Is there a check engine light ?
Originally Posted by 03_BB_S2K,May 27 2010, 03:36 PM
have you tried doing a "valve adjustment?"
he have stop picking up my calls.... ill try again tomorrow..
Regardless of me pulling the coils out or not, the motor dies. It just happens to look like the coil is causing the motor to die but its not. Before this video, I pulled one by one and motor didn't die and the sound didn't go away. I forgot to get the camera so that's why I wanted to do it again but the motor started dying again.
[media]http://www.youtube.com/watch?v=1JvHQBCikvI [/media]
we took off the belt to see if that might be the cause. NOPE
next we took off the valve cover to take a look. I notice the rocker assembly have ~1-1.5mm of play. I can move it up and down. is it suppose to be like that?
