NEED HELP engine sound
Old May 27, 2010 | 12:01 AM
typewx's Avatar
Default NEED HELP engine sound
So long story short, my ap1 motor bottom end went out. The head was still good. I found a used block from lasky racing. I had the head resurface and new guides installed. the old guides were getting pretty bad. Everything done professionally through a machine shop. I put new gasket and everything that comes in the gasket kit from honda, new auto tensioner, and replaced the rocker assembly with better condtion ones. The bottom was inspected from the outside and cranking the pistons up and down. Mike from laskey racing help with the inspection of the block. unfortunately, we didn't open the bottom block but he re-assures me that its good and its ready to rock n roll. After having delay issues with my original mechanic, I paid lasky racing to assemble the head and the block together. Everything was good as we worked on putting the motor in the car. When we finally started it up. I was greet with this....
[media]http://www.youtube.com/watch?v=pyzIlkO1_Rg [/media]
I want to
what do you guys think?? bottom block or something else?? Imma give mike a call tomorrow but I wanted to see what others think of that sound...
Old May 27, 2010 | 10:59 AM
typewx's Avatar
any ideas??
Old May 27, 2010 | 11:04 AM
crank's Avatar
have you checked the electrical? such as ignition pull the plugs see how they look, do a compression check get an OBD2 scanner. eliminate things one buy one and you will find the problem. make sure the injectors are clean/ignition is working exc.
Old May 27, 2010 | 11:06 AM
crank's Avatar
i am assuming since the motor was built by people who know how/what to do that the mechanical aspect is fine, i think it might be something simple so check the simple stuff. If i was you i would buy new plugs, put them in, run the motor for a few minuts then let the engine cool down and pull the plugs and see if any are fouled. plugs can tell you a lot !!
Old May 27, 2010 | 12:29 PM
typewx's Avatar
I put in new NGK sparks plugs when the motor was started. the have been properly gap before installed.
should I pull the coil pack one by one to see if i can isolate the cylinders?
Old May 27, 2010 | 02:05 PM
typewx's Avatar
will installing a oil pressure gauge tell me anything?
Old May 27, 2010 | 02:29 PM
crank's Avatar
i would first pull the plugs out and see how they look. then post the results.
as far as an oil pressure guage, that prolly wont tell you much since the motor dosent idle smoothly, but you can still try it. I would pull the plugs see how they look put them back in and then pull the injectors connector one by one and listen to the motor. and do the same for the coil packs, do this systematically and slowly, right down what you find if you have too. Also do a compression test just for good measure
crank's Avatar
how long have the fuel injectors been sitting ?
Old May 27, 2010 | 02:49 PM
typewx's Avatar
I notice that engine stay on much longer during cold start then later. The motor would not die for a good min or two or three when I started up this morning to pull the coil out and see. as time goes by the motor would die out faster regardless of me pulling the coils or not. I will take out the sparks plugs take some pictures right now
Old May 27, 2010 | 03:11 PM
typewx's Avatar
here are the plugs. the cleanest one is the cylinder closest to the front of the car
