Need help interpreting compression results [fixed]
Old Sep 23, 2009 | 04:07 PM
  #21
CKit's Avatar
Injectors.
Old Sep 23, 2009 | 06:05 PM
  #22
Saki GT's Avatar
Not relating to the rough idle, but compression. As for the #4 cylinder, here's a question to others - do 01s still have the 2 hole banjo bolts? The oil starvation/lack of enough oil may be wearing out the #4 cyl faster than the rest, right?
Old Sep 23, 2009 | 06:26 PM
  #23
turbo_slug's Avatar
[QUOTE=Saki GT,Sep 23 2009, 06:05 PM] Not relating to the rough idle, but compression.
Old Sep 24, 2009 | 03:48 PM
  #24
ahrmike's Avatar
Have you tried swapping coilpacks and seeing if the misfires switch cylinders? or are they misfires on different cylinders @ the same time? If the plug had somehow fried a CP you'd be able to pinpoint which one, maybe.
Old Sep 24, 2009 | 05:37 PM
  #25
turbo_slug's Avatar
[QUOTE=ikeyballz,Sep 24 2009, 03:48 PM] Have you tried swapping coilpacks and seeing if the misfires switch cylinders? or are they misfires on different cylinders @ the same time?
Old Sep 24, 2009 | 06:40 PM
  #26
ahrmike's Avatar
^Ah, that sucks man. Damn assholes trying to rip people off.
Hope you get it all fixed up, its a mighty fun car to drive when its running properly.
Old Sep 24, 2009 | 07:01 PM
  #27
starchland's Avatar
where you located bro
? was it private seller?
Old Sep 24, 2009 | 08:37 PM
  #28
turbo_slug's Avatar
i'm in vancouver and yes, private sale...
seller is actually a member of s2ki
Old Sep 25, 2009 | 01:41 AM
  #29
turbo_slug's Avatar
Another update...
I removed the valve cover to be certain that the valve retainer keepers haven't sunken..here are the pictures...i see nothing wrong with them so far?
I didn't have any feeler gauges so I wasn't able to check valve clearances. I'm going to go buy some since the valve cover is already removed.
cylinder 1
cylinder 2
cylinder 3
cylinder 4
Old Sep 26, 2009 | 12:01 PM
  #30
starchland's Avatar
from my view the cams look to have some odd wear (scratching) for any honda motor. my guess would be from lack of lubrication. However this may just be common wear on the f20...anyone can comment?
