Need help! Left rear wheel area noise!
Old Mar 14, 2006 | 02:01 PM
  #31
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by mic_crispy,Mar 14 2006, 10:44 AM
i torqued the nut to spec (220) and it was in the same position that it was before
did you remove it first?
Old Mar 14, 2006 | 02:04 PM
  #32
Billman250's Avatar
Top Answer: 1
Originally Posted by dbzerk,Mar 14 2006, 03:38 AM
Pressed the hub out of the bearing..
This is how it looked:
Need a new one huh?
Originally Posted by billman250,Mar 6 2006, 06:42 PM
3-nut still loose....the shifting hub will wear itself out where it contacts the race, as the race surface is 3X as hard
4-nut still loose....along with a ruined hub, the two inner bearing races will move out of alignment with each other, destroying the wheel bearing
Stage 3 and 4 ruined hub.
Old Mar 14, 2006 | 04:04 PM
  #33
Race Miata's Avatar
Originally Posted by modifry,Mar 7 2006, 09:02 PM
Is that grease or wear-out on the balls? They look like raisins.
Old Mar 14, 2006 | 06:33 PM
  #34
Billman250's Avatar
Top Answer: 1
Those are all clean and dry. And destroyed
Old Mar 14, 2006 | 06:35 PM
  #35
mic_crispy's Avatar
yeah.
umm so if the noise stopped (popping / clicking) i should be okay?
Old Mar 15, 2006 | 04:57 PM
  #36
mic_crispy's Avatar
im really at a loss.. i lowered my car down a bit today.. and it came back. but it doesnt do it as often as before (maybe because im still not as low in the rear as i was?)... so the leads me to believe that it may not be the axle nut? its very fustrating! i really dont want to hurt my car... maybe ill go up to stock height.
Old Jun 28, 2006 | 02:56 PM
  #37
F20C PWR's Avatar
My car started to make the popping noise ..i hope theirs no damage done
Old Jun 28, 2006 | 04:24 PM
  #38
iDomN8U's Avatar
Originally Posted by Billman250,Mar 7 2006, 06:05 PM
Listen.
Unstake the nut (use a small special shaped punch to raise up the bent-over part of the nut)
Take the nut off, and put a light coat of grease on the face of the nut where it contacts the hub. NOT the threads. If the nut comes off rough all the way to the end, use some WD40 to lube the threads. the reason for this is WD40 IS NOT a good lubricant, but it will cut the corrosion. we don't want grease, or a good lube, on the threads or the nut will get serverly overtorqued. You think LOOSE is a problem follow this to a T.
put it back on and torque it to 220. Watch how far your old stake mark moves Re-stake it in the new spot.
Is this issue specific to certain years? From the looks of it, it isn't
Do you need to remove the Rim in order to get at the nut?
Is this issue regarding both front and rear hubs?
Thank you
Old Jun 28, 2006 | 06:25 PM
  #39
F20C PWR's Avatar
i can't get the damn axle nut off
how much will a new axle nut,wheel bearing, and hub will cost? and labor?
Old Jun 28, 2006 | 09:18 PM
  #40
Ek9's Avatar
Ek9
Banned
From Majestic Honda
204804 002 2 HUB ASSY., RR. NO COLOR 119.60 89.70
30891 036 2 BEARING ASSY., FR. HUB NO COLOR 89.71 67.28 Qty:
28640 014 2 NUT, SPINDLE NO COLOR 2.39 1.80 Qty:
Majestic charges the second number. If you go to my dealer, you'll end up paying 30% more than the first #. Don't know if they all goug that way.
