NEED HELP My VTEC doesnot work !!!!!!
Old Dec 6, 2002 | 05:06 PM
conejo's Avatar
Default NEED HELP My VTEC doesnot work !!!!!!
Please my check engine light is on after Washing the engine and VTEC doesnot begin to work over 5900 RPM....What can it be....
Old Dec 7, 2002 | 01:03 PM
slick rick's Avatar
Take it to a dealer or borrow a scan tool and get the codes. Then it will shed some light as to what it can be. My guess is that something came loose a sensor or something like that. It doesn't necessarily have anything to do directly with Vtec either. I could be as simple as a temp sensor or something like that. My guess is that it's not a big deal and can easily be fixed.
Old Dec 7, 2002 | 02:21 PM
conejo's Avatar
Thnak you SlicRick I am positive that something small has happened because I just wash the engine and everything has gone Ok before that, but what sensor is it or where do I look for inside the engine????
Thanks in advance
Old Dec 7, 2002 | 03:00 PM
xviper's Avatar
[QUOTE]Originally posted by conejo
[B]Thnak you SlicRick
Old Dec 7, 2002 | 03:24 PM
w1ngman's Avatar
Originally posted by xviper
...or you can pull the ECU fuse (for 30 seconds) on the underdash fuse panel, however, I wouldn't pull it in case you [or dealer] need to know exactly what the code was.
Just thought I'd restate xviper's point above... Just in case he decides to read the first stuff (and head out the door towards his fuse box) before the post finishes loading on-screen and he has a chance to read this excellent point.
- Dave
Old Dec 7, 2002 | 03:27 PM
xviper's Avatar
[QUOTE]Originally posted by w1ngman
[B]
Old Dec 7, 2002 | 06:09 PM
chipperman's Avatar
Huh? What post was that?
Old Dec 7, 2002 | 06:27 PM
xviper's Avatar
Old Dec 7, 2002 | 08:07 PM
Gernby's Avatar
Former Sponsor
TOO DAMN FUNNY!
I used to wash my engine every time I washed my car. However, one time I started my car after spraying it, and it would just barely run. The car limped home, and I found that my dristributor cap had cracked (due to the dramatic heat change). I replaced it, and it was better (not all the way better, just mostly better). The car was never the same. I drove that car for another 90K miles, and I never could figure out what the deal was. About every 50 miles, it would have this sudden loss of power that felt like the A/C compressor turning on, even when the A/C was turned off. Since then, I have just maintained a dirty engine.
Old Dec 7, 2002 | 08:42 PM
Bieg's Avatar
[B]Please my check engine light is on after Washing the engine and VTEC doesnot
