need help taking off door panel....
Old Aug 9, 2003 | 06:28 PM
BlueS2000Boy's Avatar
Default need help taking off door panel....
i'm having a wicked rattle inside my passanger door. so i need to take the inside panel off and do a drive like that so i can see what is rattling. is it all the taps that pop out or is there any screws? any advice would help thanks.
Old Aug 10, 2003 | 06:40 AM
Pinky's Avatar
I don't have pictures to reference though here goes:
2 screws behind the little pop out plugs in the door grip.
Door handle opener there is a screw behind there.(then take plastic cup it held in out)
I think that is all there is.(might be one more at the top left corner but not 100% right now just double check)
Now grip the bottom of the door and pull. There are plastic pop offs behind the whole outside of the door.
Lift the door up slightly to take out of window track and unplug the wires to the window switch.
Reverse process to put back on.
Old Aug 10, 2003 | 07:45 AM
Fongu's Avatar
Lucid has a front speaker installation guide that shows how to disassemble the door panel. Enjoy.
http://www.lucidautomotive.com/guides/doorspeaker/
Old Aug 11, 2003 | 04:20 AM
dlq04's Avatar
https://www.s2ki.com/forums/showthread.php?...threadid=102642
Old Aug 11, 2003 | 11:11 AM
i removed the door panel and tried to see what the rattle is but i couldn't find anything at all. i guess i am going to have to take it to honda and let them figure it out.
Old Aug 11, 2003 | 12:21 PM
Pinky's Avatar
Does it still rattle with the door panel off? Is anything in the bottom of the door inside?
If it's the passenger side see if the passenger can pin point it.
Good luck.
Henwhee
Jun 20, 2012 06:43 PM
WPS
Feb 15, 2006 05:11 AM
dierk
Jul 31, 2005 04:54 AM
Shiskine
Jul 8, 2005 03:25 AM
JamieS2K
Oct 20, 2004 07:28 AM
