need help on turning off the srs light
Old Jul 3, 2002 | 02:48 PM
mdrx7's Avatar
Default need help on turning off the srs light
I just bought a car from a friend which did custom interior. He accidently had the key in while working with the air bag. The system need to be rest but I don't want to pay the money to do so. Can anyone help me rest the computer without the dtc??
Thanks.
Jay
Old Jul 3, 2002 | 02:52 PM
lucid's Avatar
id have a pro look it over. If the light is on it may be for a reason. If work was done in that area and something tinkered with you dont want cover a potential problem.
Pay the money, it may save your life!
Old Jul 3, 2002 | 02:54 PM
mdrx7's Avatar
Thanks for the reply. I am sure the airbags is fine. The light came on because when he detached the harness, the ignition was on.... Thanks for the tip though.
Old Jul 3, 2002 | 03:05 PM
demonderrick's Avatar
ok, if you unpluged it, you are facing the same thing I faced... go Honda dealer, tell them to reset the light..!! cuz without the machine, it won't turn off...!! it shouldn't cost you anything and more than 5 minutes... (if they take your car right away)(claimed that how you know you can't unplug it and plug it back) hope this helps!
Old Jul 3, 2002 | 07:07 PM
PAS2KNut's Avatar
Moving to Under the Hood.
Old Jul 3, 2002 | 08:32 PM
Utah S2K's Avatar
Sorry my friend but your kinda hosed. The SRS system is somewhat "sacrad".....read...don't mess with the airbags!!! In order to reset the DTC you need a service connector (Ref: P/N: 07PAZ-0010100). If your very electro savy you could jump the connector with a Helm Manual and software from http://www.obd-2.com/. Not knowing you or your level of knowledge I would say take it to the dealer for a reset, probably cheapest if you don't know OBD-II.......if you REALLY know your stuff send me a PM. This is not an easy reset; as you apparently have already found out.
Utah
Old Jul 3, 2002 | 09:38 PM
mdrx7's Avatar
Thanks fellows... I guess I have to take it to the dealership.
Old Jul 4, 2002 | 05:47 AM
marcucci's Avatar
You don't have to.
You do need the service manual, or PM me and I will look it up for you. There is a two-pin diagnostic plug that needs to be shorted in sequence to clear any SRS trouble codes. If there truly is a problem (sounds like there is not) then the code will resurface. You will have thrown a code if the key was turned on w/the airbag removed.
S_3000
Dec 27, 2006 05:50 PM
jules2k
May 27, 2006 09:52 AM
ahbongkadah
Oct 21, 2005 04:37 PM
S2drag
Feb 10, 2004 10:53 PM
KaCee
Jun 14, 2002 03:58 PM
