Need Help, Will this work?
Old Jun 5, 2001 | 06:40 PM
vapors2k's Avatar
I need tires for the Spoon SW388 wheels, the size is 16x7 in the front with 35mm offset and 16x8 in the rear with 45mm offset.
As for tires go, I want wider, but don't want to rub. Car is at stock height and probably wont be lowered. What's the widest I can go? will this work?
225/50 for the front
245/45 for the rear
Is that too optimistic for proper clearance with fenders/liners? Or should I go with:
215/55 for the fron
245/50 for the rear
Old Jun 6, 2001 | 11:52 AM
vapors2k's Avatar
anyone?~!?!!?
Old Jun 6, 2001 | 12:14 PM
mingster's Avatar
[QUOTE]Originally posted by vapors2k
[B]I need tires for the Spoon SW388 wheels, the size is 16x7 in the front with 35mm offset and 16x8 in the rear with 45mm offset.
Old Jun 6, 2001 | 12:50 PM
Wesmaster's Avatar
Just FYI, I'm running 245/45/16 Bridgeston Potenza S02 Pole Positions on my back stock rims - works fine.
Wesmaster
Old Jun 7, 2001 | 04:55 AM
cmnsnse's Avatar
I have 225/50 in front and 245/45 rear with stock rims but the fronts are wider than they need to be so Im going back to 205/55
Old Jun 7, 2001 | 08:40 AM
Colin's Avatar
I doubt you'll rub, but your critical front to rear "contact patch ratio" will be a bit off. Depending on how hard you drive on the street, you may or may not see any oversteer..
Old Jun 7, 2001 | 11:22 AM
vapors2k's Avatar
thnx guys for the feedback, went ahead and ordered 245/45 for the rear and 205/55 for the front. We'll see how this combo works in next weekend's auto-x.
keefss2k
Jul 7, 2009 05:37 PM
infra
Mar 27, 2008 12:09 PM
VIC4UF
Oct 16, 2005 12:33 PM
Fantasi07
Apr 23, 2005 12:14 PM
mcs2000si
Dec 23, 2003 11:50 AM
