need help! window wont roll up
Old Apr 28, 2008 | 10:19 AM
1320performancefreak's Avatar
Default need help! window wont roll up
need help after i put my top down and now my passager side window wont roll back up again. both switch are good. motor is good ( i jump 12 volt to the motor it rolls up the window) after i roll up the window by jumping the 12 volt the window will still roll down if i put down/up my top. every thing else in the passager door works just window wont roll down or up by the switch. super weird problem i will give you $20 bucks if u can help me figure it out SERIOUSLY!!! this is pissing me off........
$20 paypal if u help me solve it!!!!
Old Apr 28, 2008 | 10:57 AM
petawabit's Avatar
do you have your window locks on, the switch near the window controls? I know putting your top down will bypass the lock, but will prevent you moving the window up and down still. sorry if this sounds patronizing, but seems like something that can be overlooked
Old Apr 28, 2008 | 01:01 PM
fast-or-move!'s Avatar
i had the same problem the first day i had mine until i messed with that switch and it solved all probs.
Old Apr 28, 2008 | 01:56 PM
MikeyCB's Avatar
I am thinking it's the lock switch on the driver door, which will be the most frustrating thing in the world since he took the time to wire up the motor directly.
Old Apr 28, 2008 | 03:15 PM
shotiable's Avatar
+1, i think theres something up with the lock switch.
Old Apr 28, 2008 | 03:16 PM
shotiable's Avatar
i know.... i've been messing with my gf everytime she goes into the car, i tell her that her window is broken so she cant roll it down >.<
Old Apr 28, 2008 | 03:37 PM
not the lock switch. the 3rd thing i checked.
Old Apr 28, 2008 | 04:17 PM
vjarnot's Avatar
You checked that it was set to "off"? Or did you check it with a meter to make sure it worked properly?
Old Apr 28, 2008 | 05:23 PM
both i didnt use a meter but i switch it out with my buddy's s2k switch
Old Apr 28, 2008 | 05:36 PM
SOHCmyDOHC's Avatar
bad relay? hence it works when jumped. not sure how the window relay looks like or how its wired.
look for the # 8 relay (20A) located under dash fuse/relay box.
Did you check i your switch works on his car?
