need help! window wont roll up
Old Apr 28, 2008 | 05:49 PM
1320performancefreak's Avatar
going to check the relay tomorrow its way too hot. and yes my switch are working on his car.
Old Apr 28, 2008 | 05:51 PM
SOHCmyDOHC's Avatar
I hope your relays are the same since I forgot yours was RHD!
It should be in your passenger side!
Old Apr 28, 2008 | 06:05 PM
LOL i hope so i still have not figure out where is the power door lock control modular located at. errr sucks but i have been fixing this car up and it has come along pretty well only thing left is the air condition and keyless entry system.
already fixed: CEL for missing air pump and all its equipment, air bag system, new convertible top conversion from a 05, anti lock break light, fixed the bump steer and many many little stuff here and there.
Old Apr 28, 2008 | 07:08 PM
21337R's Avatar
Have you tried resetting the switch? I had a similar problem that this took care of. The first time I did the reset the fix only lasted 1 day, then after I reset them again, I haven't had any issues in 3 weeks. When the window is up pull up on the switch and hold it until you hear a click, the switch will be inoperable for a moment after you hear it. Then once it rolls down, roll it all the way down, release, then push and hold down again until you hear it click again. Try that and see if it helps.
Old Apr 28, 2008 | 07:23 PM
islackmore's Avatar
I had this problem with my car and it was fixed under warranty. I don't remember much but i know this:
it wasnt the motor
it wasnt unit/switch that physically has the buttons that you use to put the windows up/down (on either the passenger or the drivers side).
It was some sort of switch/relay that forces your windows down when you put the top down. I don't remember exactly what it's called but I can look it up if you still cant figure it out. This has happend to at least 3 other people that ive heard of besdies myself.
If this info doesnt help (and I'm sure it wont because I'm being vauge), then I can go tear through my invoices and look for the exact name of the part. PM me.
Old Apr 28, 2008 | 07:52 PM
thx for all the help guys early tomorrow morning i will start figure it out.
Old Apr 29, 2008 | 08:29 PM
21337R's Avatar
I am ready for my $20 when you are.
Old Apr 29, 2008 | 08:50 PM
not the switch for sure reset all the switch even use my buddys switch didnt help. cant find the relay since every thing is in japanese. errr
Old Apr 29, 2008 | 09:47 PM
R3DS2K's Avatar
did you jump the power from the switch and right at the motor>?
woody97124
Aug 23, 2014 01:46 AM
TJF
Oct 28, 2010 12:06 PM
Benn-O
Jul 4, 2010 10:22 AM
the fan
Apr 30, 2010 11:39 AM
ViruX23
Aug 28, 2005 02:17 PM
