Need new clutch!?
Old Aug 9, 2006 | 06:15 PM
tdubS2K's Avatar
Default Need new clutch!?
Well i guess since my MY01 S2K's clutch is slippin like a motha it's time to invest in a new setup. At first it was slipping in/past VTEC (~7k) in WOT, now it's starting to at half throttle. I have the 100k mi extended warranty (i'm @ 60k now) and i kno about the manufacturer's recall about the tranny buzz so i'm thinkin maybe I can try to pull one of those cards...if not i guess i'll try a DIY. but anyway any ideas/recommendations for a replacement (ie ACT)?
PS mods: AEM V2 intake, header, bored out cat, HKS cat-back, and bored out tb.
Old Aug 10, 2006 | 12:29 PM
kfdon's Avatar
i think ACT HDSS should be good for your mods
take a look into it
Old Aug 10, 2006 | 01:02 PM
SpitfireS's Avatar
IMO the clutch is a wear item.
Are you sure it is included in the warranty?
Btw.. it is "clutch-buzz" not tranny buzz.
And if you would take a mechanic out for a drive to let him listen to the clutch buzzing I think he will notice the clutch slipping too.
2 different things.
But if they replace your worn clutch under warranty for you.
Old Aug 10, 2006 | 01:15 PM
importkid's Avatar
with those mods to your car you will be lucky if they replace anything.
Old Aug 11, 2006 | 08:13 AM
RIDGERCR's Avatar
I went with the ACT heavy duty clutch kit a couple years ago. But now I have to replace the disc as I have revved up the car too many times and it sounds like a spring might have broken loose. I don't have an upgraded disc, but am just using the factory unit which might be why I'm having this problem to begin with.
If you're doing it yourself, best of luck to you as it takes at least 4 hours just to pull the tranny out, which includes disconnecting one of the engine mounts just to get clearance to reach the upper 2 bolts.
Its a tough job and I don't want to go through that again so its off to the shop for this job.
My .02.
Old Aug 11, 2006 | 08:31 AM
davidvonyork's Avatar
Banned
recall on tranny buzz? I have a 2000 s2000 that is bone stock, and somtimes i hear a really hi pitched whine when i decel.....my clutch does not slip, and i want to know if honda is giving out replacements on the clutch? If this is true about a recall, i want to go get mine, anybody know info on this, please IM me.
im at 63k miles, and no clutch problems, ecept wierd whinning occasionally.
Old Aug 13, 2006 | 05:31 AM
tdubS2K's Avatar
well i'm hoping that the honda dealership i go to will follow the precedent of my brother's subaru dealership and do warranty work (his car is stage 2)...basically they'll do warranty work for a modded car if they like you and you're not a prick. if not i'll just try to get them to replace the clutch disc (tsb).
Old Aug 13, 2006 | 05:33 AM
tdubS2K's Avatar
2 different things.
thats why the honda tsb lists it as transmission buzz.
Old Aug 13, 2006 | 11:45 AM
Picturepro's Avatar
look into this...
Competition Clutches
https://www.s2ki.com/forums/index.ph...1&t=400118&st=
Old Aug 13, 2006 | 03:25 PM
SpitfireS's Avatar
tdubS2K Posted on Aug 13 2006, 03:33 PM
Do they?
Read all the way to Slows2k's post.
https://www.s2ki.com/forums/index.php?showtopic=412924
