Need new rotors or what
Old Apr 7, 2007 | 06:31 AM
shakes's Avatar
Default Need new rotors or what
Hi, I just took my car out after a long winter, I noticed that after about 100kmh, my break pedal pulsates like crazy, I have cross drilled rotors but I think they are a cheap brand, are they warped, will putting them on a brake machine solve the problem or are they shot, Im assuming its cause is beacuse of the cheap metal in rotor, anyway if anybody can chime in it will be appreciated.
Old Apr 7, 2007 | 08:44 AM
VAD's Avatar
VAD
A vibration from brakes isn't always a "warped" rotor. http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Having them turned on a brake lathe will probably solve the problem, though. Drilled and/or slotted rotors are hard on machine tips, so they have to be turned slowly, which takes patience. When I do them, I always charge more because of that. If you have them turned, make ABSOLUTE sure that they are within spec. The machinist should have that info. If he doesn't, take your rotors elsewhere. Tell him you want before and after thickness measurements. After having them turned, break them in as if they are new. http://<br /> <a href="http://www.st...tock.shtml</a>
Old Apr 7, 2007 | 08:45 AM
VAD's Avatar
VAD
Oh, and since you just took it out of storage, give them a good bleeding!
Old Apr 7, 2007 | 09:08 AM
shakes's Avatar
If they are not warped, then whats wrong friction deposits, it only happens on hard braking, when they heat up.
Old Apr 7, 2007 | 09:32 AM
VAD's Avatar
VAD
The deposits are what make them feel warped, causing the vibration. Or, they could actually be warped if they're cheapos as you say they are.
RoosterS2K
Nov 5, 2010 02:38 AM
hellspare
May 5, 2009 12:50 PM
moey1188
Apr 12, 2007 04:27 AM
bluesaint
Jun 30, 2006 09:53 PM
NYS2K
Jun 8, 2006 11:05 AM
