Need some help
Old Jun 16, 2008 | 06:22 PM
dtmcnamara's Avatar
Default Need some help
Ok so I pulled my header off to do my clutch swap and my dumbass breaks my O2 sensor on it some how. I got a universal BOSCH from Advanced and put it in. My car runs fine, but sometimes when I turn it off and turn it back on it will start acting up when i first start to drive. If I give it gas it will sometimes hit about 3,000 rpms and then act like its hitting a rev limited and bounce, but VERY slowly. After about 3-5 second of bouncing off 3K it will rev fine.
If I try to drive I generally only get about 10 feet before it starts to act up. I have to push the clutch in and give it a few revs and then its fine, but its only if the car sits for like 5-10 minutes. If it sits overnight its fine to drive right when i start it.
Like i said the ONLY thing i changed is my O2 sensor. They idiots at Advanced said that they cannot be sure that it is my O2 sensor because my check engine light isnt on. I told them that its the ONLY thing done to the car. I drove the car with the broken O2 sensor home but once I got home I had to pull it out and replace it and that is the DAY it started.
It sounds like my O2 sensor correct?
Old Jun 16, 2008 | 07:29 PM
Mrfixit687's Avatar
go buy the oem o2 and put it in
Old Jun 17, 2008 | 11:50 PM
frofro24's Avatar
Old Jun 18, 2008 | 03:24 AM
dtmcnamara's Avatar
im guessing that the OEM one is just that much better. how much do they run $150? $200
Old Jun 18, 2008 | 02:04 PM
Kirpich's Avatar
Nah, not that much. call your local junkyard, or go to car-part.com for some junkyard ph. numbers.
Mark K.
Sky1air
Mar 10, 2016 05:13 PM
conors2k
Jul 26, 2014 08:21 AM
lbodagh
Feb 3, 2014 03:15 PM
DNTBLO_S2k
Mar 30, 2008 02:10 PM
hi50
Jun 24, 2003 05:57 AM
