Need some Info asap!
Old Feb 15, 2012 | 03:53 PM
AZ-S2000's Avatar
Default Need some Info asap!
So good news, I have a cool mechanic who is replacing my Stage-4 (after one month, can't stand it) with stock for total of $ 300.00 and at this point I would also like to replace both side bearings in the rear. I get rough grinding on turns and smooth on straights. I figure its worth replacing and not waiting till they give out. Basically what I wanna know is what is the part number or which number is it in the diagram?
I kind of figured it might be # 36 if so great.. I might as well. At this point I can also tighten it with the new torque specs that Billman says.
Old Feb 16, 2012 | 07:42 AM
dwight's Avatar
I'm pretty sure you are correct. #2 looks like the hubs that Billman showed me, and the wheel bearing is what goes on it. Good luck with the fix.
Old Feb 16, 2012 | 08:03 AM
Drkphnx's Avatar
Yes, you are correct, just had one of mine replaced.
Old Feb 16, 2012 | 08:16 PM
AZ-S2000's Avatar
Well first I'll try to tighten the bolt down and see if that fixes the problem, if not new bearings are in the order list.
yamaha6611
Mar 15, 2019 08:43 AM
WarrenW
Jun 10, 2018 01:34 AM
TopGear
Aug 3, 2010 07:46 AM
dumbkid
Oct 29, 2007 08:38 PM
scoobyrex
Dec 26, 2005 07:55 PM
