Need spark plug socket...what size?
Old Feb 23, 2010 | 02:51 AM
NFRs2000NYC's Avatar
Default Need spark plug socket...what size?
Like the thread title says, I need to do some maintenance on my car, and need to buy a good spark plug socket. Does anyone recall what size it is?
One of these should do the trick right?
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=95487
Old Feb 23, 2010 | 05:44 AM
Saki GT's Avatar
https://www.s2ki.com/forums/index.php?showtopic=765375
5/8" or 16 mm - 5/8 if you want to be exact, its like 15.86mm or something. And you don't need a swivel socket - you go straight down into the engine, so you will need a 8" extension.
Old Feb 23, 2010 | 09:27 AM
FitzyS2k's Avatar
and also make sure the socket has a rubber donut in it so that it grabs the spark plug when pulling it up.
Old Feb 23, 2010 | 09:43 AM
Slows2k's Avatar
5/8 is a standardized size for most spark plugs.
Old Feb 23, 2010 | 11:19 AM
AngryTurtle's Avatar
do any spark plug sockets not have this?
Old Feb 23, 2010 | 01:48 PM
Slows2k's Avatar
Yeah, when the rubber piece falls out.
Old Feb 23, 2010 | 01:49 PM
Suzuka_Joe's Avatar
get a 8in long socket. i always seem to have the problem with the socket coming off the extension and getting stuck on top of the spark plug
Old Feb 23, 2010 | 03:42 PM
dammitjim's Avatar
^^ That problem is a pita. Can anyone recommend a decent 8-10" spark plug socket? I'm sure Snap on sells one but I don't think I'd want to pay their prices
Or do locking extensions like these work?
http://www.amazon.com/Pro-Grade-Locking-Ex...t/dp/B00123QN3M
HF version
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=99882
Old Feb 23, 2010 | 04:01 PM
ahrmike's Avatar
^I use spark plug socket to remove the spark plug, and a 15(?) or 16mm wrench to install it. the rubber does something to catch the plug as you torque it and the socket gets stuck inside unless you have a locking extension.
Old Feb 23, 2010 | 04:33 PM
RedY2KS2k's Avatar
I have a spark plug socket (5/8" aka 16mm) that has a small hole all the way through on one side of the drive square. I also have a 3/8" impact extension with a pin retainer, rather than a ball retainer. Guaranteed to pull the socket off the spark plug every time; then just use a small pin punch through the hole to remove the socket from the extension.
