new clutch, SC not removed
Old Sep 3, 2003 | 03:14 PM
CMiS2K's Avatar
I just had a new clutch installed today. It took the shop 7.5 hrs. The vortech supercharger didn't have to be removed, but the alternator did. With the alternator removed this freed up enough room to drop the subframe out from under the car.
The ACT PP, Toda Flywheel and OEM disk feels awesome! I am taking it easy and shifting at 5500.
I killed the car twice leaving the shop and once at a stop sign. It is sensitive.
Just wanted to post an FYI and to clear up many questions regarding this subject
Old Sep 3, 2003 | 03:52 PM
honda9krpm's Avatar
cmis2k, does it feel any different from the oem?
Did you read my thread about slipping clutch?
I am not sure why there is a "break in" thing for the clutch but that's what most ppl believe in. Take it easy on the clutch buddy just to be safe
Mine has improved since last time I reported it slipping. I wonder if the clutch was too hot, back then as I just came back from a hill run when I noticed that it slipped.
Old Sep 3, 2003 | 04:24 PM
CMiS2K's Avatar
The clutch is much different than the OEM.
It is more sensitive than OEM on the engagement point. It engages much quicker.
I will be really easy.
Old Sep 3, 2003 | 04:35 PM
cdelena's Avatar
Any time you are mating new friction surfaces there is a break-in period. It is true for brakes, clutches, gearing, as well as engines. When ignored it can reduce the life and effectiveness of the components.
Old Sep 3, 2003 | 05:46 PM
fperra's Avatar
I have the same setup except a Spoon FW. A little more clutch force required with your left foot, but much better feel than stock. Engagements are much more positive. I've put about 100 miles on my car since the turbo/clutch install (https://www.s2ki.com/forums/showthread.php?...threadid=135964 ) and I haven't stalled out once. This is what stock should have been.
Old Sep 4, 2003 | 09:21 AM
Jason00S2000's Avatar
That's not bad. The shop I had my clutch done at took an amazingly quick 2.5 hours or so. Dropped the subframe pretty low, then tilted the tranny / motor back enough to get all the bolts.... bam! Tranny's out and that's it.
Old Sep 4, 2003 | 09:33 AM
CMiS2K's Avatar
But did your clutch install cost you $350 US?
Jason,
are you going to sell the 9 psi pulley or what? I sent you an e-mail back.
Old Sep 4, 2003 | 09:41 AM
ViruX23's Avatar
wtf? 7.5 hours?
Old Sep 4, 2003 | 09:53 AM
CMiS2K's Avatar
WTF is because the supercharger was left in. Many people on this board stated that the SC had to be uninstalled. He did this with the SC still in the car. So WTF? huh?
A local owner did his own install and took him over 15 hours of install time and he didn't have a SC on his car.
Old Sep 4, 2003 | 10:58 AM
ViruX23's Avatar
lol, why am i not suprised...
anyway, im not fimaliar with the SC but what is it about it that would add 4 hours to the install?
