NEW S2000 OWNER w/ High Beam Problem
#21
#23
I swapped out the relays on nothing changed. If it is actually two burned out high beam bulbs, wouldn't the dash indicator still light up even if the bulbs are burned out? I have a bad feeling that if I swap out the bulbs, I will still be without high beams. Thoughts?
I also saw a thread (that I no longer can find) about the solder points on a lighting module. Could that be the issue?
Have you tried this thread with the circuit board have bad soldering???
https://www.s2ki.com/forums/s2000-un...orking-959048/
#24
Appearing more and more like the light stalk is the issue.
Service Manual, (all years.)
2008 Wiring Manual (but this isn't completely applicable to cars earlier than 2006 which lack DRLs).
-- Chuck
-- Chuck
#25
#26
*** UPDATE ***
I removed the steering wheel column surround and cannot figure out how to remove the actual turn signal stalk. I can't find any videos about it either. Can you direct me to instructions on how to do it?
Thank you!
Thank you!
#27
have you tested the wires instead of tearing the car apart?
#28
#29
22-126 is the test procedure. use a multimeter.
bad_driver (11-22-2023)
