NGK spark plugs from dealer (H and A & Honda)
Originally Posted by Billman250,Jan 4 2011, 10:34 AM
store bought ngks will not come pre gapped.
Honda bought ngks are pre gapped for the s2k. Out of approximately 100 honda plugs that I have installed, every single gap was spot on.
Originally Posted by s2000maniac,Jan 4 2011, 07:14 PM
^^ this is how I gapped my NGK's and so far I have gone 3000+ miles with no problems. gapping them like the picture above will not damage anything unless you keep moving the electrode back and forth. you just have to be little careful and save yourself over 30 dollars.
Thats just one more possible way to damage the tip of the spark plug and coating.
The way I was taught to gap spark plugs is actually the way that NGK shows in their instructional videos which I think is a better way then using the flat disc use to measure the gap which can crush the tip, and trying to tap the metal to close the gap or bending it with the tool show in S200maniacs diagram
[media]http://www.youtube.com/watch?v=lk70oyUEftY [/media]
Well duh, he's using the coin tool wrong! The outer lip is for measuring only. You use the hole in the tool to adjust the gap -- it has a thin, strong inner ridge that will pry open the gap without ever touching the center tip.
I always wondered why people were so afraid of the coin-style tool; now I guess I know.
Just my opinion, but someone has to gap the plugs - they don't come out of the forge at the magical number for S2000s - maybe for a more popular car, but S2000s are low volume.
The trick is to do it once and not go back and forth in adjustments, which will weaken the metal. When plugs are made they get a 90° bend from a machine on the production floor - the fine-point adjustment for specific gap is done by hand, so if Honda OEM plugs come pre gapped, that is because some person adjusted the gap for the plug, which is no different from you doing it on a regular plug.
I've known people to pull their plugs regularly, clean them off, adjust gap, and reinstall them, and they've never had any issues. I think the conception with gapping comes from people that bend the hell out of them and weaken the electrodes and from people that pull their plugs for the first time after 100k mi and are amazed that the electrode is missing from wear, and think it broke off.
Originally Posted by CapoArgentino,Jan 13 2011, 12:48 PM
Bought some OEM NGKs from Majestic. They come in a red Honda and NGK marked box. Beautiful
Originally Posted by Billman250,Jan 13 2011, 08:09 AM
I cant believe NGK put their name on that vid.
I've been gapping plugs for a long time now, and if people can't gap spark plug correctly, then changing their oil might be a stretch as well. For Christ's sake people, just make sure you're doing it correctly, and you'll be fine. If you're touching the tip at all of the plug, you're not doing it right. Paying a fortune just to get pre-gapped plugs is ridiculous. If you're really that non-mechanically inclinced, then by all means by them pre-gapped, but I'm willing to bet 90% of people can gap spark plugs.
