No Spark ...
Old Apr 20, 2017 | 12:51 PM
J.J's Avatar
J.J
Default No Spark ...
Swapped in a new engine in my AP1. Car has no spark with Crank sensor plugged in but will spark if I unplug the sensor. I tried my crank sensor off my old engine and that didn't change anything. Only other thing I can think of is the ECM. Car ran just a couple months ago, find it hard thing believe the ECM randomly failed. How common do the ECM fail, anyone else got no spark from a faulty ECM?
Old Apr 20, 2017 | 01:23 PM
noodels's Avatar
Got crank sensor the right way round ?
got a plug in the wrong place, back of cam cover maybe ?
That's me done
Old Apr 21, 2017 | 05:17 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Cam timing. ECU is fine.
Did you put the top end together on the new engine or was it a complete swap?
Old Apr 21, 2017 | 08:04 AM
J.J's Avatar
J.J
I never checked the cam timing. Engine only has 30k miles. I assumed it was correct. That is something I can cross off, does anyone know what resistance the Crankshaft sensor is supposed to have?
Old Apr 21, 2017 | 09:13 AM
Billman250's Avatar
Top Answer: 1
You bought a complete running engine, and didn't have to build any of the top end correct?
Old Apr 21, 2017 | 09:30 AM
J.J's Avatar
J.J
Yes, motor came out of a wrecked s2000 complete. I figured the timing was correct but I guess stranger things have happened. I've double and triple checked everything else. The fact it will spark if I unplug the crank sensor has to mean something just not sure what. No trouble codes, unless I unplug the crank sensor then it throws that code. I'll check the cam timing tonight.
Old Apr 21, 2017 | 10:51 AM
Billman250's Avatar
Top Answer: 1
It means the motor is out of time. In this condition, it will only run with the CKP sensor disconnected.
Pop the cover and have a look. Possibly someone did some tct work and disturbed the crank with it removed.
Old Apr 21, 2017 | 11:25 AM
J.J's Avatar
J.J
Thanks for the advice I'll check it tonight and post an update.
Old Apr 21, 2017 | 01:41 PM
J.J's Avatar
J.J
Intake cam seems to be a tooth out. Whats the best way to sync them back up?
Old Apr 21, 2017 | 02:27 PM
J.J's Avatar
J.J
At DTC I'm assuming both cam triggers should be at 12 o'clock. Is that correct or not necessarily...
