No Spark ...
Old Apr 21, 2017 | 02:50 PM
Chuck S's Avatar
At TDC on cylinder 1 (front of engine) the marks on the cam chain sprocket (mostly hidden below your straight edge) should align with the cylinder head surface and cam marks just above your straight edge should point directly at each other. I can't see the cam chain sprocket thru your hand and the straight edge is hiding the cam mark on the cam on the left in the photo.
(Photo courtesy Robrob.)
-- Chuck
Old Apr 21, 2017 | 02:57 PM
J.J's Avatar
J.J
I think I'm going to move the exhaust up to the intakend mark. Not sure which cam I should be moving. Intake is high, exhaust is low ... which one is right?
Old Apr 21, 2017 | 03:00 PM
Hfreak's Avatar
I cannot see any reason why your timing would not be correct from an engine that was pulled out of a wrecked car that was running, but anything is possible. I would pull both cam sensors and clean the tips, have seen this issue before. Good luck.
Need a better pic as mentioned by Chuck.
Old Apr 23, 2017 | 12:24 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It does not look off.
Make the camwheel marks level.
Then getvthe camera a little lower to take the pic. No straight edge needed.
Old Apr 23, 2017 | 12:30 PM
J.J's Avatar
J.J
I actually figured it out. Car was an AP2 2004 bUT the guy put 06+ sensors and I guess tuned it with kpro or something. So I had to swap all the triggers, not fun.
Old Apr 23, 2017 | 12:31 PM
J.J's Avatar
J.J
Old Apr 23, 2017 | 03:45 PM
Hfreak's Avatar
Great that you figured it out and you have a 2.2 in your AP1, awesome.!
GJ02SPJ
Jan 3, 2017 02:56 AM
Paperboy7777
Sep 12, 2013 05:35 AM
Real talk
Oct 16, 2012 09:36 AM
durtbikedude365
Nov 12, 2010 08:56 PM
CaymanS2k
Jun 8, 2007 03:50 AM
