No start
Old Dec 10, 2006 | 05:53 PM
  #41
chrisesteban's Avatar
Old Dec 11, 2006 | 06:33 PM
  #42
Billman where u at?
Old Dec 12, 2006 | 06:23 PM
  #43
azunboy's Avatar
i had the cranking with no start and it pointed to ecu failure, swapped ecu's and flashed it and its running great.
Old Dec 12, 2006 | 06:30 PM
  #44
did u get spark from the plugs? be4 the ecu swap.
  #45
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
So what's the last word on the cam timing? I can't let this one go, since it hasn't fired since the re-build.
Old Dec 12, 2006 | 06:37 PM
  #46
Billman250's Avatar
Top Answer: 1
Originally Posted by chrisesteban,Nov 21 2006, 04:16 PM
can u install the black ring backwards?
For some reason, I thought I saw "afterwards".
If I remember correctly, it doesn't matter which way it goes in, as it's symetrical.
Old Dec 12, 2006 | 06:49 PM
  #47
the cam timing is off by 1-2 teeth. does that matter? can the ecu hav gone bad? the cams are giving a signal but the ecu is not giving the c.o.p the signal to spark.
Old Dec 12, 2006 | 06:58 PM
  #48
Slows2k's Avatar
Yes, the engine will not start with the cam timing off at all when using a stock PCM. Install the camshafts correctly.
Old Dec 13, 2006 | 02:18 AM
  #49
Billman250's Avatar
Top Answer: 1
Originally Posted by Billman250,Nov 20 2006, 08:12 PM
FYI...If the cams are one tooth off, the engine will not start. Might be a good place to start after a motor rebuild.
Dude I told you that a month ago, and I've said it like 4 times after. come on man....
Old Dec 13, 2009 | 08:50 AM
  #50
i build motors all day's Avatar
I have the same issue. I was thinking maybe the TDC sensors that are used to set ignition timing at START UP. there are two of them and that might be it I have spark fuel compression and the car wants to fire and nothing.
FireDog
Sep 13, 2013 02:08 PM
jdmrick
Jul 23, 2011 10:28 AM
boy blue11
Aug 25, 2010 10:25 AM
MacGyver
Oct 1, 2001 06:19 PM
