No start after engine swap
Old 11-24-2017, 09:41 AM
s2000ellier's Avatar
Default No start after engine swap
Swapped my original motor back in after spinning a rod bearing in my F24.
Car cranks and fires/runs briefly for a half second sometimes before dying.
I've verified the 3 ground (back of cylinder head, 2 near AC.
Checked all fuses, none are blown.
Swapped ignition coils between my two S2000, swapped injectors between them too.
No CEL are on.
Timing is correct
Does anyone know if having no airbags/stock seat belts connected prevents startup?
Old 11-24-2017, 09:58 AM
flanders's Avatar
Are you using stock ecu or Haltech?
Seat belts and airbags seems very unlikely to be the cause, hopefully someone else can confirm 100%.
clutch interlock switch is also bypassed
Old 11-24-2017, 10:00 AM
stock ap1 ecu
i swapped in the ap2 ecu i had from my other s2000, but that one throws the bad ECU code
Old 11-24-2017, 10:02 AM
i can see fire poof out the throttle body (have no intake on) when i crank sometimes so i know its getting fuel and spark
fuel rail was also full of fuel when i swapped injectors
pulled the plugs and they were good, normal electrode, color was blackish
Old 11-24-2017, 10:18 AM
Old 11-24-2017, 10:19 AM
Old 11-24-2017, 10:59 AM
noodels's Avatar
Problem I had was one rear cam sensor was in wrong way as the tab had broken
Old 11-24-2017, 11:02 AM
the sensor on the valve cover or the plate on the back of the camshaft?
i actually just swapped the two sensors on the valve cover just in case but that didnt make a difference
Old 11-24-2017, 11:06 AM
noodels's Avatar
on the cover,<one for each cam>
Quick Reply: No start after engine swap
