is this normal?
Old Feb 16, 2007 | 04:36 PM
KJ1225's Avatar
Default is this normal?
I noticed this oil resiude on the cylinder head where the belts and pullies are, theres always oil residue there, everytime I wipe it off a month later it re-appears.
Does anyone have this issue as well? or is this not an issue at all?
Here are some pics of what I'm talking about
Thanks!
Old Feb 16, 2007 | 04:40 PM
FISH22's Avatar
no, this is not normal. i wouldnt say its the head gasket, cause the head gasket is directly below it. maybe a crack in the head, idk
Old Feb 16, 2007 | 04:42 PM
jimi's Avatar
I would check the torque on those bolts then see if it re-appears. Hope not, Good luck
Old Feb 16, 2007 | 04:46 PM
FISH22's Avatar
looked at it closer, definitley looks like something in the cast. i'm not sure if tightening down those bolts would do anything. jb weld might hold it for a bit.
Old Feb 16, 2007 | 06:27 PM
KJ1225's Avatar
hmmm I inspected it and there isnt any cracks that I can see. could it be the belts flinging stuff up?
Old Feb 16, 2007 | 06:33 PM
SenderGreen's Avatar
Porus Block?
EDIT:Correction, Porus cylinder head?
Old Feb 16, 2007 | 06:46 PM
Slows2k's Avatar
It's a Porous casting, and not performance issue. You could mix up some JB Weld epoxy and apply a thin coat to the leak area to prevent it from coming back. There is no pressurized oil supply behind the cylinder head in that location.
Porous castings are not that common, and I've epoxied up several of them.
Old Feb 16, 2007 | 07:15 PM
KJ1225's Avatar
is this a defect? should I be worried and will it cause any problems down the road?
Old Feb 17, 2007 | 03:05 AM
KJ1225's Avatar
bump
Old Feb 17, 2007 | 06:24 AM
Slows2k's Avatar
Technically it is a defect, but I wouldn't replace the cylinder head to repair. If you car was still under warranty Honda would epoxy it 1st.
