is this normal for the engine?
Old Sep 28, 2004 | 10:29 AM
PapiChulo's Avatar
Default is this normal for the engine?
this is a pic of the engine bay of a S2k im considering buying, looking at it ive noticed the "stain" between the block and head .... is this something i should be worried about ? we are goin to run a compression and coolant test on it before i pick it up but im looking for a headsup or a dont worry .
Old Sep 28, 2004 | 11:05 AM
cdelena's Avatar
It is actually the timing chain galley on the other side of the stain, and yes it is common, and there is nothing to worry about.
Old Sep 28, 2004 | 11:09 AM
Elistan's Avatar
Pretty much every engine I've looked at had something like that there.
Old Sep 28, 2004 | 11:49 AM
PapiChulo's Avatar
Thanks, just was curious if i should have been worried,
When im compression testing it , is there a EFI fuse or something to disable the fuel and spark ? or how do i go about disabling teh fuel and spark so i can test it ?
Old Sep 28, 2004 | 02:38 PM
xviper's Avatar
Pull the fuel pump fuse. With the spark plugs out of the engine, the coil packs will be out too and won't be hooked up with their corresponding wiring harnesses. You won't have to worry about spark.
acn684
Nov 17, 2011 02:05 PM
Elroy
Jan 26, 2009 09:17 PM
Tom Jr
May 13, 2007 03:15 PM
05S22
Aug 22, 2005 05:21 PM
gfacter
Dec 12, 2004 07:41 PM
