not going into gear
Old Aug 17, 2013 | 08:59 AM
ValleyN/AS2K's Avatar
Default not going into gear
im having some issue with my car right now. i just put a 4 puck ACT clutch in and the car goes into all gears when the car is off. but when i start the car it wont go into any of the gears. i have bleed the clutch, adjusted the rod where the pedal is, there are no leaks, and i installed the clutch correctly. im thinking it maybe on of the sensors on the tranny. any got any ideas.
Old Aug 17, 2013 | 10:28 AM
Nemi's Avatar
I don't think there are any sensors related to gearing on the S2k. Did you replace the throwout bearing when you changed the clutch?
Old Aug 17, 2013 | 11:07 AM
yes i did.
Old Aug 17, 2013 | 12:17 PM
when i put the car into gear and then try to start it, it wont start it just keeps cranking over and over.
Old Aug 18, 2013 | 11:33 AM
AZ-S2000's Avatar
Pressure plate. What pressure plate did you use? Was it a kit? Or did you use OEM pressure plate with ACT clutch? I am almost dead certain on it because I had the same issue and it turned out to be the pressure place.
Old Sep 6, 2013 | 09:17 AM
it is a Fidanza fly wheel, and ACT 4 puck clutch kit
Old Sep 6, 2013 | 09:24 AM
baZurk's Avatar
Almost sounds like the pressure plate and disk was mated incorrectly to the flywheel and it is binding up. Sorry to say it, but you may have to pull the whole clutch assembly back out.
Old Sep 7, 2013 | 12:24 PM
AZ-S2000's Avatar
+1
s2klariat
Jan 16, 2014 09:25 AM
krnmike
Apr 16, 2009 02:34 AM
Boostedtaco
Nov 19, 2008 04:45 PM
dandaman2883
Nov 6, 2007 04:51 PM
Beave0101
Nov 30, 2004 02:07 PM
