Not hitting redline
Old Aug 17, 2015 | 08:17 PM
FZXtreme's Avatar
Default Not hitting redline
Hello All,
I went to the track this past weekend and during the later sessions I noticed that after a few laps the car would not rev up to 9k.
As in one lap I would rev up to 9k, the next lap the car will only rev up to 8700 then 8500 and lower with every passing lap.
I thought that it was heat soak as it was a hot day and the car didn't get a chance to properly cool in between sessions but I can't find any info with people having the same situation as me so i thought I'd ask if anyone has had a similar experience and this is indeed heat soak that I am experiencing.
I have an 01 with a k&n intake, catback exhaust, haltech ecu tuned, seiko catch cans, and ingalls torque damper if that info is useful.
Thanks.
Old Aug 17, 2015 | 08:22 PM
afzan's Avatar
Did you talk to your tuner?
Old Aug 17, 2015 | 10:12 PM
windhund116's Avatar
Check the status of the spark plugs?
Old Aug 17, 2015 | 10:56 PM
davidc1's Avatar
Not heat soak at all. I don't know how much you know about engines and how they work and sound if there is a problem, but what you describe can be do to gradually increasing misfires as the season goes on. The question would be, what is causing the misfires.
Old Aug 17, 2015 | 11:03 PM
s2000Junky's Avatar
Could also be starving for gas?? High G turns, less and less fuel in the tank. Not uncommon to come out of a turn and put your foot down and have it feel like you hit a wall intermittently.
Old Aug 18, 2015 | 05:28 AM
B serious's Avatar
How's your oil level?
Old Aug 18, 2015 | 01:23 PM
FZXtreme's Avatar
Have not but will get in touch soon.
Took all of them out today and I can't spot anything except the one for cylinder 3 being blacker than the rest and what looks to be dust/dirt on some of them. I am not expert so I took pics to let others judge.
I like to think that I know a bit about engines and I can't say that I heard anything when I was driving it hard. It would drive like normal, no loss of power, no harsh vibration or sounds, it just started to bounce off the rev limiter before redline so I had to shift up earlier and earlier. I checked it out after the first instance and didn't hear or feel anything wrong with the engine, there was some valve tick but it was quiet so I didn't suspect anything from it.
It only happened on the straights where I was able to reach the high rpms, out of the turns i never felt any power loss but I get what you're saying.
I topped it off before I went onto the track and kept track of it in between sessions. I am anal when it comes to checking my oil level and I never let it drop below the half way point on the dip stick.
Old Aug 18, 2015 | 02:33 PM
afzan's Avatar
Its probably some kind of (overheat?) protection that your tuner added into your tune
Old Aug 18, 2015 | 02:48 PM
FZXtreme's Avatar
That's what I'm thinking as well.
Ill have to get in touch with him to see if that is the case.
Old Aug 18, 2015 | 05:42 PM
Slowcrash_101's Avatar
Sounds similar to the MAP issue. Those plugs look fine, you want them gray or tan at the electrode tip.
