notchy 2nd when cold, powertrain warranty?
Old 03-14-2012, 03:22 PM
wonderd's Avatar
Default notchy 2nd when cold, powertrain warranty?
Hello guys I have a 2005 S2000. When going into 2nd gear for the first 15 minutes of driving the 2nd gear is very notchy. After its warmed up its okay, but not a crisp shift. Is it possible honda would fix this problem for me under warranty(it expires in April)? I will admit that i did grind 2nd gear pritty bad a couple years ago when I first got the car, but I hear this is a common problem with S2000's so I am not sure what I would have to say in order for them to fix it for me.
Thanks
Dan
Old 03-14-2012, 03:37 PM
wonderd's Avatar
would TSB 05-009 apply? I seen it here https://www.s2ki.com/s2000/topic/434...ar-tsb-05-009/ 7th post down by chuhsi
Old 03-14-2012, 05:27 PM
NFRAP2's Avatar
That TSB is for popping out of gear issues, not notchy shifting. Notchy shifting while the transmission is cold is very common with the s2k... but if you were abusing yours by grinding 2nd gear you may have damaged the gear and/or synchro for that gear. I doubt that Honda will cover the repairs, but only they can tell you for sure... not a forum.
Old 03-14-2012, 09:59 PM
apme123's Avatar
my ap1 does the same thing, i notice if i pause while shifting it doesnt do it, it also never fells notchy shifting above 5500rpm/ I just learned to live with it.
Old 03-14-2012, 10:22 PM
MegaTRon's Avatar
change the timing of your shift. either shift faster or slower. make sure you push the clutch pedal all the way down.
Old 03-14-2012, 10:26 PM
towingtime's Avatar
Whens the last time your trans fluid was changed? The fluid is thick when its cold also so its not going to be as smooth when cold. Also make sure you clutch is good and properly bled. An old clutch will cause shifting problems also. But if your fluid may be old, id just change it, and see how it feels after that!
Old 03-14-2012, 11:08 PM
wonderd's Avatar
I have already changed trans fluid, i dont think its a bad clutch car has about 29k on it. I just know its not normal and wonder if honda would take care of it
Old 03-15-2012, 01:11 AM
MegaTRon's Avatar
its normal for all s2000 to be notchy when cold.
Old 03-15-2012, 05:13 AM
Reckon's Avatar
Definitely normal to be notchy when cold. You may want to regrease your shifter to help as you have already done a transmission fluid change. Also, timing your shifting will help.
Old 03-16-2012, 02:02 PM
starchland's Avatar
nature of the beast. ap2 tranny seems to be smoother though. make sure everything is greased up and adjusted nicely too.
Quick Reply: notchy 2nd when cold, powertrain warranty?
